| jeffdon |
Apr 2 2017, 12:24 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,094 Joined: 24-October 06 From: oakland, ca Member No.: 7,087 Region Association: None |
My car sat in the rain overnight a month ago and I am pretty sure SOME water got into the carbs. At the time it barely turned over and would not start.
Now it will not turn over at all. Pulled the plugs, jacked up one wheel, and tried to get it to move by turning the wheel. No luck. Could the water that got in have frozen it due to rust? Did I possibly create a hydro lock situation and break something? How can I break it loose? |
| r_towle |
Apr 2 2017, 06:47 PM
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States
Did you drain the oil?
Any water in the oil.? How long did it sit with water in it? |
| jeffdon |
Apr 2 2017, 10:56 PM
jeffdon Engine not turning Apr 2 2017, 12:24 PM
cgnj
My car sat in the rain overnight a month ago and ... Apr 2 2017, 12:29 PM
jeffdon
My car sat in the rain overnight a month ago and... Apr 2 2017, 12:33 PM
jeffdon Does a stock starter have enough torque to break s... Apr 2 2017, 12:34 PM
porschetub Get on to it ASAP,remove plugs and put penetrant o... Apr 2 2017, 01:55 PM
Perry Kiehl No, the stock starter won't overcome a hydro-l... Apr 2 2017, 02:16 PM
jeffdon
No, the stock starter won't overcome a hydro-... Apr 2 2017, 02:38 PM
rgalla9146
No, the stock starter won't overcome a hydro... Apr 2 2017, 03:15 PM
jeffdon What it really feels like is the time I had a bear... Apr 2 2017, 03:44 PM
Perry Kiehl
What it really feels like is the time I had a bea... Apr 2 2017, 04:18 PM
jeffdon
[quote name='jeffdon' post='2471109... Apr 2 2017, 04:37 PM
cgnj It's no longer hydro locked, think about it. T... Apr 2 2017, 07:22 PM
Mark Henry Get the water out, pull the plugs and fill the cyl... Apr 2 2017, 11:22 PM
porschetub
Get the water out, pull the plugs and fill the cy... Apr 3 2017, 09:43 PM
jeffdon Yesterday, I shot some engine oil into the holes. ... Apr 3 2017, 09:23 AM
Mikey914 Seafoam is another product that is used in this ap... Apr 3 2017, 09:45 AM
jeffdon
Seafoam is another product that is used in this a... Apr 3 2017, 09:56 AM
Mikey914 Before you drop the motor do drain it. If there is... Apr 3 2017, 10:00 AM
jeffdon
Before you drop the motor do drain it. If there i... Apr 3 2017, 10:08 AM
jeffdon Drained oil. No water visible. Apr 3 2017, 10:44 AM
jeffdon Well, its NOT the alternator. Apr 3 2017, 11:21 AM
jeffdon Dribble of water out of the heat exchangers when i... Apr 3 2017, 12:20 PM
jeffdon Engine is out. Of course, still not turning. Tim... Apr 3 2017, 03:01 PM
jeffdon I have two cylinders with rust in them. One pret... Apr 3 2017, 04:37 PM
cuddyk Sorry to see this.
Leave some penetrating oil on ... Apr 3 2017, 04:57 PM
jeffdon
Sorry to see this.
Leave some penetrating oil on... Apr 3 2017, 05:12 PM
cuddyk Tough to tell before you free the jugs ;). But th... Apr 3 2017, 05:36 PM
jeffdon
Tough to tell before you free the jugs ;). But t... Apr 3 2017, 09:24 PM
Mikey914 Pretty sure there will be some pitting. Good news ... Apr 3 2017, 07:08 PM
jeffdon
Pretty sure there will be some pitting. Good news... Apr 3 2017, 09:25 PM
Puebloswatcop
Pretty sure there will be some pitting. Good new... Apr 4 2017, 03:22 PM
porschetub Well not sure here but think that water has been i... Apr 3 2017, 09:39 PM
jeffdon
Well not sure here but think that water has been ... Apr 3 2017, 09:45 PM
falcor75 Soeak with penetrating oil
Scrape/blow away loose ... Apr 3 2017, 10:19 PM
r_towle There was water in the oil it did not disappear.
... Apr 3 2017, 11:46 PM
jeffdon
... Apr 4 2017, 09:29 AM
The Cabinetmaker If they are oem cylinders, bore them out and buy n... Apr 4 2017, 10:07 AM
jeffdon
If they are oem cylinders, bore them out and buy ... Apr 4 2017, 10:16 AM
cgnj Hi,
Probably toast from the pic. Still, if you hav... Apr 4 2017, 10:25 AM
Eric_Shea First - Hydrolock - I always put the car in 5th ge... Apr 4 2017, 10:30 AM
jeffdon I do not think I hydrolocked it. It was not start... Apr 4 2017, 10:40 AM
jeffdon Just coaxed what I thought was the worst one off. ... Apr 4 2017, 12:13 PM
jeffdon one to go.... Apr 4 2017, 02:15 PM
jeffdon All off. Phew. Apr 4 2017, 03:30 PM
Puebloswatcop What size engine is it? I might be able to help y... Apr 4 2017, 03:33 PM
jeffdon
What size engine is it? I might be able to help ... Apr 4 2017, 03:51 PM
Puebloswatcop
What size engine is it? I might be able to help... Apr 4 2017, 04:12 PM
jeffdon
[quote name='jeffdon' post='2472062' date='Apr 4 ... Apr 4 2017, 04:35 PM
markhoward Anybody out there know if its fine to use an ultra... Apr 4 2017, 04:44 PM
jeffdon
Anybody out there know if its fine to use an ultr... Apr 4 2017, 04:53 PM
markhoward sure do. used on my 911 engine build and several ... Apr 4 2017, 04:58 PM
jeffdon
sure do. used on my 911 engine build and several... Apr 4 2017, 05:06 PM
cuddyk Glad you got them all off!
I have a used set... Apr 4 2017, 05:06 PM
jeffdon And now to get the frozen rings off..... :headbang... Apr 5 2017, 09:19 AM
jeffdon Gotta a question on re-assembling, and what will a... Apr 5 2017, 09:48 AM
cuddyk Since you'll have everything apart, I'd be... Apr 5 2017, 10:14 AM
jeffdon
Since you'll have everything apart, I'd b... Apr 5 2017, 10:23 AM
injunmort you have the engine torn down that far and your go... Apr 5 2017, 06:32 PM
Mark Henry
you have the engine torn down that far and your g... Apr 5 2017, 06:38 PM
Kansas 914
The upside of not replacing the old seals is the ... Apr 5 2017, 06:43 PM
Perry Kiehl
you have the engine torn down that far and your ... Apr 5 2017, 08:32 PM
jeffdon Yeah, all good thinking. Apr 5 2017, 09:47 PM
porschetub So far current advise suggests a bit of work and t... Apr 6 2017, 12:15 AM
jeffdon Ok...new seals all around. Apr 6 2017, 09:06 AM![]() ![]() |
Lo-Fi Version | Time is now: 1st May 2026 - 08:24 AM |
