Full Version: Engine not turning
Pages: 1, 2
jeffdon
My car sat in the rain overnight a month ago and I am pretty sure SOME water got into the carbs. At the time it barely turned over and would not start.
Now it will not turn over at all. Pulled the plugs, jacked up one wheel, and tried to get it to move by turning the wheel. No luck. Could the water that got in have frozen it due to rust? Did I possibly create a hydro lock situation and break something? How can I break it loose?
cgnj
QUOTE(jeffdon @ Apr 2 2017, 11:24 AM) *
Happened to me three years ago. I'm OCD. Dropped motor, pulled heads. Lots of Marvel Mystery oil. & gentle crank turning. Rebuilt carbs. I see rain hats and tray in your future.
Carlos
jeffdon
QUOTE(cgnj @ Apr 2 2017, 11:29 AM) *
Carlos
jeffdon
Does a stock starter have enough torque to break something in the engine if there was water in a cylinder?
porschetub
Get on to it ASAP,remove plugs and put penetrant or diesel(lots )down the plug holes and let it soak then try turning it over for a while to blow the water out....hopefully your cylinder bores haven't rusted to much.
If you get it started check the oil soon after you get it going,I would suggest you change it anyway.
Good luck.
IronHillRestorations
No, the stock starter won't overcome a hydro-locked motor. Where guys get in trouble is when they roll it down a hill and pop the clutch.
The big problem is when you've got water in the combustion chamber and the engine turns over and both valves close.
Pull the plugs and look in the spark plug hole. If you can see water, suck it out one way or another (mechanical device preferred).
jeffdon
QUOTE(Perry Kiehl @ Apr 2 2017, 01:16 PM) *
It has been a few months since I first had the issue. At the time, I thought it was just my crappy old battery. Pushed it into the garage and ignored it. It is only now with a new battery that I am realizing i have a bigger issue.
Just pulled the starter, to see if that was the culprit. Still cannot turn it by hand.
rgalla9146
QUOTE(jeffdon @ Apr 2 2017, 04:38 PM) *
Plugs out.... blow out water w/ compressed air.....feed Marvel Mystery into each cylinder...... Select 1st gear... rock car back and forth on flat ground....not
too forceful !.......hope you get lucky
Oh ! one more thing..... remove the alt belt..... they can rust onto the pulleys and stop the engine from turning too
jeffdon
What it really feels like is the time I had a bearing seized on me and it wouldn't turn over. But that was on the previous build this engines been pretty solid
QUOTE(jeffdon @ Apr 2 2017, 01:44 PM) *
Ohhh. That's not good. If you're engine was hydro-locked, and you have a cylinder that's full of water, you'll probably end up with a broken ring as well.
What Rory said about the MMO is the best approach at this point.
jeffdon
[quote name='Perry Kiehl' date='Apr 2 2017, 03:18 PM' post='2471121']
[quote name='jeffdon' post='2471109' date='Apr 2 2017, 01:44 PM']
[/quote]
Jeez, how much water could have gotten in there?
r_towle
Did you drain the oil?
Any water in the oil.?
How long did it sit with water in it?
cgnj
It's no longer hydro locked, think about it. The water has had more than enough time to drop into the sump thru your ring gaps. Most likely one or more pistons have rings frozen to bore. You can recover., I dropped the motor and pulled the heads, but you may not have to go this far based on my experience. All steps others and I have mentioned. You want to free the rings not break them. I did the marvel, jerk the crank till I freed up the rings. forget the starter, avoid extra work, do it by hand. Put t back together, leak down better than 94%, I was good to go. Don't try to rush it. Or you can go overboard like I did, and add an extra weekend of work. I did rebuild my carbs while I was waiting. My car was sitting like this for 3-6 months before I realize I screwed up. I was able to recover and learned a lesson. Take advantage of my mistake.
jeffdon
QUOTE(r_towle @ Apr 2 2017, 05:47 PM) *
Nope.
Nope.
And it sat for a few months.
Mark Henry
Get the water out, pull the plugs and fill the cylinders with diesel, 3-4 days it will free up.
Spin the motor no plugs to get the diesel out.
If you have no water or diesel in the oil replace plugs and see if it will fire up.
If it does likely you lucked out, change the oil and try to get it running proper.
jeffdon
Yesterday, I shot some engine oil into the holes. Will try today to see if it turns today.
Mikey914
Seafoam is another product that is used in this application.
At this point. You are looking at a teardown. You can try to get it running and hopefully it will not have enough damage be an issue. get it running put a long weekend of driving nearby on it and see how she runs (PS pay up AAA just incase)
It is a Volkswagen and there are stories of this happening and it being fine. The real issue I can see is how much water was in the bottom, Will the cam bearings be ok ? That could be the problem
jeffdon
QUOTE(Mikey914 @ Apr 3 2017, 08:45 AM) *
I gotta think that between the rain hitting the screen in the decklid, and the fact that the throat of the carbs is only about 40mm, there could not be all that much. As of this morning, its not turning by hand. I think I am going to drop the engine today. Ugh.
Mikey914
Before you drop the motor do drain it. If there isn't much water there you will not need to pull the motor.
Are you not feeling lucky?
jeffdon
QUOTE(Mikey914 @ Apr 3 2017, 09:00 AM) *
No, not feeling lucky. I will drain it first. My gut is telling me that I broke a ring. AA pistons and cylinders. I have a hard time thinking I broke anything bigger, like a rod. Or bearing.
jeffdon
Drained oil. No water visible.
jeffdon
Well, its NOT the alternator.
jeffdon
Dribble of water out of the heat exchangers when i pulled them. Could be old condensation I guess?
jeffdon
Engine is out. Of course, still not turning. Time to tear off the heads.
jeffdon
I have two cylinders with rust in them. One pretty bad. Wonder if I can hone these? Also, How the hell am I going to get my cylinders off the pistons with the rust? Here is a pic of the worst one.
iankarr
Sorry to see this.
Leave some penetrating oil on it for a day or so. And/or carefully use a flat instrument and a hammer to gently but firmly push/tap the cylinder jugs away from the case. My guess is that you'll probably need new pistons and cylinders anyway. Good luck!
jeffdon
QUOTE(cuddyk @ Apr 3 2017, 03:57 PM) *
Sorry to see this.
Don't think a honing would do it?
iankarr
Tough to tell before you free the jugs wink.gif. But the pic looks as if there will be pitting under that rust. And if the cylinders have never been replaced, there's a good chance they're scored after 40+ years.
Mikey914
Pretty sure there will be some pitting. Good news it's a VW not a 911, so you have fewer new ones to buy and they are less expensive.
jeffdon
QUOTE(cuddyk @ Apr 3 2017, 04:36 PM) *
New pistons and cylinders. ONly about 4 years on them.
jeffdon
QUOTE(Mikey914 @ Apr 3 2017, 06:08 PM) *
Can you get less than a set?
porschetub
Well not sure here but think that water has been in there a while longer than mentioned and no it won't hone out ,best to replace the whole lot and start a fresh.
We all make mistakes so try to look on the positive side ok.
porschetub
QUOTE(Mark Henry @ Apr 3 2017, 06:22 PM) *
Funny I said that av-943.gif .
jeffdon
QUOTE(porschetub @ Apr 3 2017, 08:39 PM) *
Come to think of it, it was probably more like 3 months. I'm a dumbshit.
falcor75
Soeak with penetrating oil
Scrape/blow away loose flakes
Slowly heat the cylinder and tap the piston with the wooden handle of a hammer or similar.... rinse and repeat.....
r_towle
There was water in the oil it did not disappear.
Suck, but you can get it back .
While you are in there, DPR sells striker cranks and larger Pistons and cylinders are a click away.....just sayin.
jeffdon
QUOTE(r_towle @ Apr 3 2017, 10:46 PM) *
Still thinking boring out my old stock cylinders might be an option. I am on a super tight budget.
TheCabinetmaker
If they are oem cylinders, bore them out and buy new pistons and rings.
jeffdon
QUOTE(The Cabinetmaker @ Apr 4 2017, 09:07 AM) *
Yeah. Perhaps my pistons are ok?
cgnj
Hi,
Probably toast from the pic. Still, if you have compressor the cheap HF leakdown tool will be enough to tell you if you can save it. Till leakdown everything is a swag.
Not certain of the value of reboring cylinders vs.buying new from ems. He sent me the material data sheets for his 96 mm jugs. At the time they were not AA and he was getting them cast in the US. Worth an email to see if that's still the case.
Try to avoid becoming the next Dirk Wright.
Eric_Shea
First - Hydrolock - I always put the car in 5th gear and push it backward. huh.gif
Second - Time for a rebuild.
jeffdon
I do not think I hydrolocked it. It was not starting due to a weak battery, pretty sure. I think its a case of rusted rings/cylinders. Soaking with diesel, and tapping the pistons with a block and mallet (not too hard). I have about 3 mm of seperation between the cylinders and case. trying not to pry too much or too hard.
jeffdon
Just coaxed what I thought was the worst one off. They all seem to be stubborn.
jeffdon
one to go....
Puebloswatcop
QUOTE(jeffdon @ Apr 3 2017, 09:25 PM) *
European Motrworks sells individual cylinders and pistons
jeffdon
All off. Phew.
Puebloswatcop
What size engine is it? I might be able to help you out parts wise...for I too know what it is like to be on a tight budget...
jeffdon
QUOTE(Puebloswatcop @ Apr 4 2017, 02:33 PM) *
2056. 96mm cylinders and pistons
Puebloswatcop
QUOTE(jeffdon @ Apr 4 2017, 03:51 PM) *
Sorry, I have no 2056 parts. In fact am saving for the same. Just thought if it was a stock size I might be able to help you out. I know I just bought a 73 with the same issue. Anyway, good luck and holler if ya need anything. Still have some spare parts that might help you out at some point.
jeffdon
QUOTE(Puebloswatcop @ Apr 4 2017, 03:12 PM) *
Thanks for offering. I got a stock set of jugs. If the rusty ones are too far gone, I can have them bored. So far, only one of the cylinders looks like its got pitting. Hopping its not so far gone as to be beyond honing out.
The rings, however, seem to be rusted into the grooves. Gonna give them a long diesel soak.
The generosity of 914 people never fails to amaze me. Sniff. Must have dust in my eye all of a sudden.
