> 1983 911 Tachometer, Wiring Diagram Needed
mmascari
post Apr 3 2017, 04:28 PM
Anyone have a diagram of wiring connections for an '83 911 tachometer? I am going to connect to an MSD 6AL ignition. What are all the connections for? I suppose for turn signal lights which I don't care about.
jcd914
post Apr 3 2017, 09:22 PM
Based on the 8 pin connector on the back of the tach it is a 3.2 DME tach.
Pin 2 would be the tach signal but since it would be coming from the DME control unit I have no idea if it would work with a signal from the MSD unit.
mmascari   1983 911 Tachometer   Apr 3 2017, 04:28 PM
jcd914   Look for a terminal marked as "TD" that ...   Apr 3 2017, 05:44 PM
mmascari   Look for a terminal marked as "TD" that...   Apr 3 2017, 05:45 PM
mmascari   Look for a terminal marked as "TD" that...   Apr 3 2017, 05:47 PM
jim912928   I'm out of town so don't have access to my...   Apr 3 2017, 06:20 PM
mepstein   '83 is still 3.0 SC, not 3.2   Apr 3 2017, 06:34 PM
jim912928   edited...was a typo...I put in an 84 Carrera 3.2 m...   Apr 3 2017, 06:38 PM
Jeffs9146   I would guess #2! That tach looks different t...   Apr 3 2017, 06:44 PM
mmascari   I would guess #2! That tach looks different ...   Apr 3 2017, 07:12 PM
mepstein   This might help   Apr 3 2017, 06:49 PM
mepstein   Does it have a shift light. That would identify it...   Apr 3 2017, 07:18 PM
mmascari   Does it have a shift light. That would identify i...   Apr 3 2017, 07:28 PM
Mark Henry   Does it have a shift light. That would identify i...   Apr 3 2017, 09:39 PM
mmascari   Does it have a shift light. That would identify ...   Apr 3 2017, 09:45 PM
Jeffs9146   [quote name='Mark Henry' post='2471769' date='Apr...   Apr 3 2017, 11:56 PM
mepstein   Look for the part number above the 3 and the 4 und...   Apr 3 2017, 07:42 PM
mmascari   Look for the part number above the 3 and the 4 un...   Apr 3 2017, 08:18 PM
jcd914   Based on the 8 pin connector on the back of the ta...   Apr 3 2017, 09:22 PM
Mark Henry   If it is a DME tach is it compatible with the MSD?...   Apr 3 2017, 09:44 PM
jim912928   Shift indicator light...pretty sure that is a 3.2 ...   Apr 3 2017, 09:44 PM
forrestkhaag   An un-directly-related question but slightly relat...   Apr 4 2017, 09:21 AM
- Lo-Fi Version Time is now: 3rd March 2026 - 12:49 AM
