mmascari
Apr 3 2017, 04:28 PM
Anyone have a diagram of wiring connections for an '83 911 tachometer? I am going to connect to an MSD 6AL ignition. What are all the connections for? I suppose for turn signal lights which I don't care about.
jcd914
Apr 3 2017, 05:44 PM
Look for a terminal marked as "TD" that would be the signal input for the tach.
Jim
mmascari
Apr 3 2017, 05:45 PM
QUOTE(jcd914 @ Apr 3 2017, 04:44 PM)
Jim
Cool thanks Jim.
mmascari
Apr 3 2017, 05:47 PM
Jim
Actually, the terminals on mine are labeled 1 - 6 and HG and H+
jim912928
Apr 3 2017, 06:20 PM
I'm out of town so don't have access to my files...but here is a link where I talked about wiring an 84 3.2. References which wires in the 3.2 harness go to which numbered terminals on the tach...and then the original 914 wires to the tach. Hope this helps:
http://www.914world.com/bbs2/index.php?sho...7&hl=wiringFirst post and then the one with the lame picture of the tach installed are the ones to reference.
Jim
Apr 3 2017, 06:34 PM
'83 is still 3.0 SC, not 3.2
jim912928
Apr 3 2017, 06:38 PM
edited...was a typo...I put in an 84 Carrera 3.2 motor
Jeffs9146
Apr 3 2017, 06:44 PM
I would guess #2!
That tach looks different than mine but mine is an 82.
The stamp date is when it was manufactured not the model car it is for so it "could be" for a 3.2L. What is the part number on the inside top of the front side of the tach around the ring. Mine is 911 641 301 03.
Apr 3 2017, 06:49 PM
This might help
mmascari
Apr 3 2017, 07:12 PM
QUOTE(Jeffs9146 @ Apr 3 2017, 05:44 PM)
I would guess #2!
I cant find a 911 part number. Maybe it is a 3.2l tach. I bought it from someone that told me it was an SC tach.
Will a 3.2 tach work with a 3.0 motor?
Apr 3 2017, 07:18 PM
Does it have a shift light. That would identify it as a 3.2 tach.
mmascari
Apr 3 2017, 07:28 PM
QUOTE(mepstein @ Apr 3 2017, 06:18 PM)
No, weird huh.
Apr 3 2017, 07:42 PM
Look for the part number above the 3 and the 4 under the glass. Then you can figure out exactly what you have.
Edit - It does have an upshift light. That would make it a 3.2 tach
mmascari
Apr 3 2017, 08:18 PM
QUOTE(mepstein @ Apr 3 2017, 06:42 PM)
It does look like an SC tach to me.
Found it....thanks for pointing it out.....911 641 301 05
jcd914
Apr 3 2017, 09:22 PM
Based on the 8 pin connector on the back of the tach it is a 3.2 DME tach.
Pin 2 would be the tach signal but since it would be coming from the DME control unit I have no idea if it would work with a signal from the MSD unit.
Mark Henry
Apr 3 2017, 09:39 PM
QUOTE(mepstein @ Apr 3 2017, 09:18 PM)
What is the up pointing arrow just below the needle center?
Mark Henry
Apr 3 2017, 09:44 PM
If it is a DME tach is it compatible with the MSD?
You could use the Ashlock Tach-Adapt and just use your /4 tach or if you have any issues with that tach.
jim912928
Shift indicator light...pretty sure that is a 3.2 tach
mmascari
Apr 3 2017, 09:45 PM
QUOTE(Mark Henry @ Apr 3 2017, 08:39 PM)
LOL...so maybe it is a 3.2 tach. Will it work with a 3.0 motor/MSD
Jeffs9146
Apr 3 2017, 11:56 PM
QUOTE(mmascari @ Apr 3 2017, 08:45 PM)
I would think it will. Again try it and see if it works!
As long as you do + and - correct you won't mess it up!
forrestkhaag
Apr 4 2017, 09:21 AM
An un-directly-related question but slightly related....
What are the bulbs being shown in the backside photo of the tach by mepstein? And a source would be helpful as well if available.
Anything has to be better than the tiny squinting glinters I presently have (stock) and now is the time to try to correct that situation...... if possible... and maybe try on my CF gauge facade...
