| mmascari |
Apr 3 2017, 04:28 PM
Member ![]() ![]() Group: Members Posts: 322 Joined: 1-September 14 From: Concord, CA Member No.: 17,850 Region Association: None |
Anyone have a diagram of wiring connections for an '83 911 tachometer? I am going to connect to an MSD 6AL ignition. What are all the connections for? I suppose for turn signal lights which I don't care about.
Attached thumbnail(s) |
| Mark Henry |
Apr 3 2017, 09:44 PM
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada |
If it is a DME tach is it compatible with the MSD?
You could use the Ashlock Tach-Adapt and just use your /4 tach or if you have any issues with that tach. |
mmascari 1983 911 Tachometer Apr 3 2017, 04:28 PM
jcd914 Look for a terminal marked as "TD" that ... Apr 3 2017, 05:44 PM
mmascari
Look for a terminal marked as "TD" that... Apr 3 2017, 05:45 PM
mmascari
Look for a terminal marked as "TD" that... Apr 3 2017, 05:47 PM
jim912928 I'm out of town so don't have access to my... Apr 3 2017, 06:20 PM
mepstein '83 is still 3.0 SC, not 3.2 Apr 3 2017, 06:34 PM
jim912928 edited...was a typo...I put in an 84 Carrera 3.2 m... Apr 3 2017, 06:38 PM
Jeffs9146 I would guess #2!
That tach looks different t... Apr 3 2017, 06:44 PM
mmascari
I would guess #2!
That tach looks different ... Apr 3 2017, 07:12 PM
mepstein This might help Apr 3 2017, 06:49 PM
mepstein Does it have a shift light. That would identify it... Apr 3 2017, 07:18 PM
mmascari
Does it have a shift light. That would identify i... Apr 3 2017, 07:28 PM
Mark Henry
Does it have a shift light. That would identify i... Apr 3 2017, 09:39 PM
mmascari
Does it have a shift light. That would identify ... Apr 3 2017, 09:45 PM
Jeffs9146
[quote name='Mark Henry' post='2471769' date='Apr... Apr 3 2017, 11:56 PM
mepstein Look for the part number above the 3 and the 4 und... Apr 3 2017, 07:42 PM
mmascari
Look for the part number above the 3 and the 4 un... Apr 3 2017, 08:18 PM
jcd914 Based on the 8 pin connector on the back of the ta... Apr 3 2017, 09:22 PM
jim912928 Shift indicator light...pretty sure that is a 3.2 ... Apr 3 2017, 09:44 PM
forrestkhaag An un-directly-related question but slightly relat... Apr 4 2017, 09:21 AM![]() ![]() |
Lo-Fi Version | Time is now: 3rd March 2026 - 12:48 AM |
