> Engine not turning, No rain tray, webers
jeffdon
post Apr 2 2017, 12:24 PM
My car sat in the rain overnight a month ago and I am pretty sure SOME water got into the carbs. At the time it barely turned over and would not start.
Now it will not turn over at all. Pulled the plugs, jacked up one wheel, and tried to get it to move by turning the wheel. No luck. Could the water that got in have frozen it due to rust? Did I possibly create a hydro lock situation and break something? How can I break it loose?
markhoward
post Apr 4 2017, 04:44 PM
Anybody out there know if its fine to use an ultrasonic cleaner to loosen up the crud? Thought it might help to get things clean after lots of oil soaking. Don't think its a good idea to go very long with ultrasonic part on but the 125 degree dawn water should help loosen things.
jeffdon
post Apr 4 2017, 04:53 PM
QUOTE(markhoward @ Apr 4 2017, 03:44 PM) *
Got an ultrasonic cleaner?
jeffdon   Engine not turning   Apr 2 2017, 12:24 PM
cgnj   My car sat in the rain overnight a month ago and ...   Apr 2 2017, 12:29 PM
jeffdon   My car sat in the rain overnight a month ago and...   Apr 2 2017, 12:33 PM
jeffdon   Does a stock starter have enough torque to break s...   Apr 2 2017, 12:34 PM
porschetub   Get on to it ASAP,remove plugs and put penetrant o...   Apr 2 2017, 01:55 PM
Perry Kiehl   No, the stock starter won't overcome a hydro-l...   Apr 2 2017, 02:16 PM
jeffdon   No, the stock starter won't overcome a hydro-...   Apr 2 2017, 02:38 PM
rgalla9146   No, the stock starter won't overcome a hydro...   Apr 2 2017, 03:15 PM
jeffdon   What it really feels like is the time I had a bear...   Apr 2 2017, 03:44 PM
Perry Kiehl   What it really feels like is the time I had a bea...   Apr 2 2017, 04:18 PM
jeffdon   [quote name='jeffdon' post='2471109...   Apr 2 2017, 04:37 PM
r_towle   Did you drain the oil? Any water in the oil.? How...   Apr 2 2017, 06:47 PM
jeffdon   Did you drain the oil? Any water in the oil.? Ho...   Apr 2 2017, 10:56 PM
cgnj   It's no longer hydro locked, think about it. T...   Apr 2 2017, 07:22 PM
Mark Henry   Get the water out, pull the plugs and fill the cyl...   Apr 2 2017, 11:22 PM
porschetub   Get the water out, pull the plugs and fill the cy...   Apr 3 2017, 09:43 PM
jeffdon   Yesterday, I shot some engine oil into the holes. ...   Apr 3 2017, 09:23 AM
Mikey914   Seafoam is another product that is used in this ap...   Apr 3 2017, 09:45 AM
jeffdon   Seafoam is another product that is used in this a...   Apr 3 2017, 09:56 AM
Mikey914   Before you drop the motor do drain it. If there is...   Apr 3 2017, 10:00 AM
jeffdon   Before you drop the motor do drain it. If there i...   Apr 3 2017, 10:08 AM
jeffdon   Drained oil. No water visible.   Apr 3 2017, 10:44 AM
jeffdon   Well, its NOT the alternator.   Apr 3 2017, 11:21 AM
jeffdon   Dribble of water out of the heat exchangers when i...   Apr 3 2017, 12:20 PM
jeffdon   Engine is out. Of course, still not turning. Tim...   Apr 3 2017, 03:01 PM
jeffdon   I have two cylinders with rust in them. One pret...   Apr 3 2017, 04:37 PM
cuddyk   Sorry to see this. Leave some penetrating oil on ...   Apr 3 2017, 04:57 PM
jeffdon   Sorry to see this. Leave some penetrating oil on...   Apr 3 2017, 05:12 PM
cuddyk   Tough to tell before you free the jugs ;). But th...   Apr 3 2017, 05:36 PM
jeffdon   Tough to tell before you free the jugs ;). But t...   Apr 3 2017, 09:24 PM
Mikey914   Pretty sure there will be some pitting. Good news ...   Apr 3 2017, 07:08 PM
jeffdon   Pretty sure there will be some pitting. Good news...   Apr 3 2017, 09:25 PM
Puebloswatcop   Pretty sure there will be some pitting. Good new...   Apr 4 2017, 03:22 PM
porschetub   Well not sure here but think that water has been i...   Apr 3 2017, 09:39 PM
jeffdon   Well not sure here but think that water has been ...   Apr 3 2017, 09:45 PM
falcor75   Soeak with penetrating oil Scrape/blow away loose ...   Apr 3 2017, 10:19 PM
r_towle   There was water in the oil it did not disappear. ...   Apr 3 2017, 11:46 PM
jeffdon   There was water in the oil it did not disappear. ...   Apr 4 2017, 09:29 AM
The Cabinetmaker   If they are oem cylinders, bore them out and buy n...   Apr 4 2017, 10:07 AM
jeffdon   If they are oem cylinders, bore them out and buy ...   Apr 4 2017, 10:16 AM
cgnj   Hi, Probably toast from the pic. Still, if you hav...   Apr 4 2017, 10:25 AM
Eric_Shea   First - Hydrolock - I always put the car in 5th ge...   Apr 4 2017, 10:30 AM
jeffdon   I do not think I hydrolocked it. It was not start...   Apr 4 2017, 10:40 AM
jeffdon   Just coaxed what I thought was the worst one off. ...   Apr 4 2017, 12:13 PM
jeffdon   one to go....   Apr 4 2017, 02:15 PM
jeffdon   All off. Phew.   Apr 4 2017, 03:30 PM
Puebloswatcop   What size engine is it? I might be able to help y...   Apr 4 2017, 03:33 PM
jeffdon   What size engine is it? I might be able to help ...   Apr 4 2017, 03:51 PM
Puebloswatcop   What size engine is it? I might be able to help...   Apr 4 2017, 04:12 PM
jeffdon   [quote name='jeffdon' post='2472062' date='Apr 4 ...   Apr 4 2017, 04:35 PM
markhoward   Anybody out there know if its fine to use an ultra...   Apr 4 2017, 04:44 PM
jeffdon   Anybody out there know if its fine to use an ultr...   Apr 4 2017, 04:53 PM
markhoward   sure do. used on my 911 engine build and several ...   Apr 4 2017, 04:58 PM
jeffdon   sure do. used on my 911 engine build and several...   Apr 4 2017, 05:06 PM
cuddyk   Glad you got them all off! I have a used set...   Apr 4 2017, 05:06 PM
jeffdon   And now to get the frozen rings off..... :headbang...   Apr 5 2017, 09:19 AM
jeffdon   Gotta a question on re-assembling, and what will a...   Apr 5 2017, 09:48 AM
cuddyk   Since you'll have everything apart, I'd be...   Apr 5 2017, 10:14 AM
jeffdon   Since you'll have everything apart, I'd b...   Apr 5 2017, 10:23 AM
injunmort   you have the engine torn down that far and your go...   Apr 5 2017, 06:32 PM
Mark Henry   you have the engine torn down that far and your g...   Apr 5 2017, 06:38 PM
Kansas 914   The upside of not replacing the old seals is the ...   Apr 5 2017, 06:43 PM
Perry Kiehl   you have the engine torn down that far and your ...   Apr 5 2017, 08:32 PM
jeffdon   Yeah, all good thinking.   Apr 5 2017, 09:47 PM
porschetub   So far current advise suggests a bit of work and t...   Apr 6 2017, 12:15 AM
jeffdon   Ok...new seals all around.   Apr 6 2017, 09:06 AM
- Lo-Fi Version Time is now: 1st May 2026 - 08:21 AM
