> A Texas Sized Project - 1975 2.0L, 12/8/20 - Wiring & Interior Update
aggiezig
post Jul 13 2016, 03:31 PM
Porsche Wannabe
Hi 914World,
New(ish) member with new project - a 1975 2.0L. It's certainly a project, but I think it's a great starting place. The seller is extremely knowledgeable about the car and helpful with local contacts who are in the 914 scene. It's been on the local CL for a while for more than I wanted to pay, but was recently able to strike a deal. Here are some specs about the project:
  • "Rust Free" car with the only rust being on the surface of cleaned metal
  • Hell-hole looks very clean
  • All original glass, bumpers, interior, suspension, rims, etc. are included
  • 901 "side shift" transmission has been taken apart, inspected, and rebuilt
  • Lowered hard mounts for drivetrain
  • There are some spares included as well (doors, top, misc. / etc.)
The engine is the gem of this purchase in my opinion. Here are the details:
2055cc "build" project in pieces currently (with matching numbers)
  • All balanced / clearance as necessary by H&H in Dallas
  • 96mm Pistons / Cylinders
  • 9.0:1 compression ratio
  • 3-angle valve job on 2.0 Heads
  • Iskenderian Cams #485128 Grind #VP-228
  • Claude's Buggies' Lightened Lifters
  • Lightened Flywheel
  • Custom High RPM Cooling Fan
  • Rotating assembly has been coated with polymer or ceramic coatings by Polymer Dynamics in Houston
I've put down a deposit to hold and will be picking up on Monday. I'll post pictures as soon as I can. Plans are for a mostly stock rebuild with an attempt to retain as much value as possible.
Looking forward to this one!
aggiezig
post Apr 12 2017, 03:57 PM
Porsche Wannabe
If you will recall, I was missing both factory trunk hinge mounting points from my car as the PO removed them for some unknown reason. Well, last night I got around to fitting the new J West trunk pivot mounts with heim joints. Overall, it wasn't too bad of a process. The hardest part was figuring out exactly where I wanted to align the trunk lid to still have maximum future adjust-ability. It's not perfect, but it's pretty good.
Here is the lid taped down after we shimmed (with an old valve cover gasket) to get the lid where we wanted it:
(IMG:http://www.914world.com/bbs2/uploads_offsite/i120.photobucket.com-19557-1492034249.1.jpg)
Then, I crawled underneath and marked the holes with a sharpie. The trunk lid had to be removed to drill the holes, and even then two of them were challenge because of the angle you have to attack them from. Here is the mounted J West pivot:
(IMG:http://www.914world.com/bbs2/uploads_offsite/i120.photobucket.com-19557-1492034285.1.jpg)
Lastly, a pic with the trunk hinge installed and in place:
(IMG:http://www.914world.com/bbs2/uploads_offsite/i120.photobucket.com-19557-1492034286.2.jpg)
Also realized last night I might not be able to fit my Camp 914 struts while the car is still in the rotisserie as you cannot open the trunks all the way... (IMG:style_emoticons/default/blink.gif) Oversight on my end.
post Apr 12 2017, 04:50 PM
QUOTE(aggiezig @ Apr 12 2017, 02:57 PM) *
You could have welded that in place. Probably not a bad idea to seam weld it if you can grind a clean spot on that piece. I believe that JWest hinge is for those that don't want to weld. Enjoying your build thread. (IMG:style_emoticons/default/beerchug.gif)
aggiezig
post Apr 12 2017, 11:28 PM
Porsche Wannabe
QUOTE(76-914 @ Apr 12 2017, 05:50 PM) *
I did kick that idea around before getting started. But, I ultimately decided against it because I figure the pivot will get more sheer strength from the two plates being bolted together on either side of the inner fender wall. Who knows, but somehow I rationalized it in my head. I will be painting the black brackets body color to help disguise them.
On another note, glad you're enjoying watching my learning curve (IMG:style_emoticons/default/av-943.gif)
aggiezig   A Texas Sized Project - 1975 2.0L   Jul 13 2016, 03:31 PM
Frankvw   Welcome. Good luck with the pickup. Looking forwar...   Jul 13 2016, 03:38 PM
theleschyouknow   :wttc: glad to see another Texan on the board sou...   Jul 13 2016, 04:10 PM
76-914   :wttc: and I would like to see a pic of that speci...   Jul 13 2016, 04:38 PM
Shadowfax   :wttc: From NW Louisiana. :white914:   Jul 13 2016, 05:19 PM
aggiezig   As promised, here are some pics. From the origina...   Jul 13 2016, 07:44 PM
aggiezig   Oops - found some additional pics from original ad...   Jul 13 2016, 07:50 PM
barefoot   Oops - found some additional pics from original a...   Jul 14 2016, 06:52 PM
zambezi   curious about that fan with the axial flow impell...   Jul 14 2016, 10:33 PM
aharder   :wttc:   Jul 14 2016, 04:17 AM
Beebo Kanelle   Gig 'Em   Jul 14 2016, 05:30 AM
Grelber   Was the engine one that Wes did?   Jul 14 2016, 07:52 AM
aggiezig   Was the engine one that Wes did? Will have to c...   Jul 14 2016, 07:57 AM
blackmoon   :wttc: It looks like you have your work cut out fo...   Jul 14 2016, 08:27 AM
H&H1981   H&H is still open, in case you have heard diff...   Jul 14 2016, 09:24 AM
aggiezig   H&H is still open, in case you have heard dif...   Jul 14 2016, 09:27 AM
stuttgart46   Great to see another 914 in Texas.   Jul 14 2016, 04:33 PM
aggiezig   Will see what I can find out on the fan. No big up...   Jul 17 2016, 11:06 PM
rjames   I'd look closely at the hell hole again. May...   Jul 18 2016, 10:25 PM
Elliot Cannon   It will be a bit of work but when done it will be ...   Jul 18 2016, 11:18 PM
aggiezig   Just thought I would share real quick - I picked u...   Jul 18 2016, 11:41 PM
aggiezig   Ok, as promised here are some much better pictures...   Jul 19 2016, 09:09 AM
theleschyouknow   longs look good in the pic I'd check the b pil...   Jul 19 2016, 02:07 PM
aggiezig   The organization has begun! I went through all...   Jul 20 2016, 09:22 AM
Claus Graf   Congrats! Looks like you got a solid 914 with ...   Jul 20 2016, 12:52 PM
aggiezig   So, today she is a roadster again: http://www.914...   Jul 22 2016, 07:53 PM
Rob-O   The organization has begun! I went through al...   Jul 22 2016, 09:17 PM
Rob-O   The foam piece in your last pic is the passenger s...   Jul 22 2016, 09:24 PM
Rob-O   Red inserts in the seat aren't original. But ...   Jul 22 2016, 09:28 PM
Rob-O   Sorry to keep adding posts, but just saw another p...   Jul 22 2016, 09:50 PM
Larmo63   I feel sorry for you, I really do. You've cau...   Jul 22 2016, 11:03 PM
barefoot   2055cc "build" project in pieces current...   Jul 23 2016, 06:14 AM
cuddyk   :wttc: Congrats! Looks like you've got pl...   Jul 23 2016, 06:41 AM
charliew   Welcome to the world site. My son is a aggie me su...   Jul 24 2016, 10:09 AM
aggiezig   Rob-O - thanks for the help / advice. Much appreci...   Jul 24 2016, 10:56 AM
aggiezig   After a sweat-filled couple of hours this afternoo...   Jul 24 2016, 09:06 PM
Rob-O   After a sweat-filled couple of hours this afterno...   Jul 24 2016, 09:35 PM
aggiezig   Quick update. I've spent a couple of nights wo...   Jul 28 2016, 09:45 AM
Rob-O   I would replace for peace of mind. I'm sure y...   Jul 28 2016, 11:37 AM
aggiezig   Tonight I went through my cases of engine parts to...   Aug 2 2016, 10:42 PM
aggiezig   Spent the evening with Jay @ H&H in Plano. Gre...   Aug 3 2016, 08:48 PM
aggiezig   Pulled the 'teener out to load up and move fro...   Aug 11 2016, 11:08 AM
aggiezig   Picked up the parts car this afternoon. It's a...   Aug 14 2016, 10:11 PM
porschetub   Looks like a good sound base for a resto,not as ro...   Aug 15 2016, 03:51 PM
aggiezig   Quick update for you guys. I pulled the front susp...   Sep 24 2016, 10:55 PM
aggiezig   Got the parts car moved out of my storage unit and...   Oct 4 2016, 10:05 PM
Larmo63   There are some parts that you intend to powder coa...   Oct 4 2016, 10:55 PM
aggiezig   Picked up some shiny clean parts today... http://...   Oct 17 2016, 04:51 PM
aggiezig   I was inspired by the octagon / rotisserie that Re...   Oct 30 2016, 09:29 PM
Cairo94507   Nice project and you are making good time too. I ...   Nov 1 2016, 08:12 AM
aggiezig   Thanks, Cairo. I definitely appreciate his help. ...   Nov 2 2016, 09:12 PM
aggiezig   All done... just needs a 914 inside of it! ht...   Nov 5 2016, 10:24 PM
aggiezig   It was a little bit of a challenge, but my 914 is ...   Nov 6 2016, 06:14 PM
mbseto   Nice work. I'm kind of fascinated by these oc...   Nov 7 2016, 11:02 AM
aggiezig   Spent a little time this weekend working on some o...   Nov 16 2016, 09:34 PM
aggiezig   Well, it's been a month but I was finally able...   Dec 11 2016, 06:44 PM
aggiezig   Time for a few updates… While I was out of town,...   Jan 15 2017, 07:58 PM
aggiezig   Playing around with some paint stripper... http:/...   Jan 18 2017, 11:42 PM
Vacca Rabite   Decided not to blast it? Zach   Jan 19 2017, 01:55 PM
aggiezig   Decided not to blast it? Zach I'm weighing ...   Jan 19 2017, 02:22 PM
aggiezig   Time for some sheet metal updates.... Here's ...   Jan 23 2017, 12:22 PM
aggiezig   Next up... front trunk floor! The front panel ...   Jan 23 2017, 12:35 PM
aggiezig   I've been making a lot of progress on unexpect...   Feb 9 2017, 10:56 PM
aggiezig   Well, this will be a pretty big update. After spot...   Feb 11 2017, 11:01 PM
Cairo94507   Very nice working documentation. That is going to...   Feb 12 2017, 08:09 AM
jmitro   nice work. Looked exactly like my crusty old car   Feb 12 2017, 08:59 AM
aggiezig   Thanks for the kind words, gents. Small update, b...   Feb 28 2017, 10:41 PM
StratPlayer   Amazing job, well done :first: :first:   Mar 1 2017, 05:23 PM
76-914   Grinding down rosette welds takes the Fun right ou...   Mar 1 2017, 07:36 PM
aggiezig   Amazing job, well done :first: :first: Thank...   Mar 1 2017, 10:32 PM
Cairo94507   :popcorn: :popcorn:   Mar 2 2017, 07:21 AM
aggiezig   The repair saga continues... doubler is in and so ...   Mar 2 2017, 11:10 PM
aggiezig   Small update... I just got a truck load of parts b...   Mar 21 2017, 03:22 PM
aggiezig   Finally got a chance to get in the garage and play...   Mar 23 2017, 09:20 AM
aggiezig   Time for another update! Today we finished up ...   Mar 25 2017, 11:12 PM
aggiezig   Took her out, flipped her over, and got her wet. :...   Mar 26 2017, 11:02 PM
aggiezig   Gotta keep going while I'm on a roll... I us...   Mar 27 2017, 10:46 PM
aggiezig   Some small updates, but first a little day-dreamin...   Apr 3 2017, 11:54 PM
jesse7flying   Great work and great thread! I've got the...   Apr 4 2017, 09:51 AM
aggiezig   Great work and great thread! I've got th...   Apr 4 2017, 08:57 PM
aggiezig   Took the plunge last night and decided there was n...   Apr 6 2017, 08:26 AM
aggiezig   Spent most of today at the Mecum auction in Housto...   Apr 8 2017, 10:24 PM
aggiezig   Few more repairs done... Here is the passenger lo...   Apr 10 2017, 12:10 PM
aggiezig   If you will recall, I was missing both factory tru...   Apr 12 2017, 03:57 PM
76-914   If you will recall, I was missing both factory tr...   Apr 12 2017, 04:50 PM
aggiezig   You could have welded that in place. Probably not...   Apr 12 2017, 11:28 PM
aggiezig   My hell hole repair is finally completed!...   Apr 14 2017, 09:29 PM
aggiezig   Here's a nice break from all the metal work......   Apr 30 2017, 08:37 PM
aggiezig   Work has picked up and progress has screeched to a...   May 15 2017, 10:31 PM
barefoot   Also bought a 3-4 side passenger tin as the one I ...   Sep 11 2017, 04:46 AM
aggiezig   Wow long time, no post. Life has gotten in the way...   Jul 9 2017, 10:54 PM
Larmo63   You aren't going to use the cooling flaps and ...   Jul 9 2017, 11:53 PM
aggiezig   You aren't going to use the cooling flaps and...   Jul 10 2017, 08:04 AM
jesse7flying   +1 on the Adriatic Blue. My 914 has been painted ...   Jul 10 2017, 09:26 AM
aggiezig   If you missed my other thread, I'm choosing ha...   Jul 23 2017, 10:46 PM
mbseto   I wish my "pecking away every now and then...   Jul 24 2017, 07:32 AM
aggiezig   I wish my "pecking away every now and then...   Jul 25 2017, 10:30 PM
aggiezig   Hello world, time for an update! Progress has ...   Sep 10 2017, 11:10 PM
porschetub   Very impressed have been following progress....POS...   Sep 11 2017, 12:28 AM
Tbrown4x4   I didn't see if anybody answered your question...   Sep 11 2017, 03:09 AM
3 Pages V  1 2 3 >
- Lo-Fi Version Time is now: 24th September 2026 - 09:42 AM
