> How Do You Fill Up Your 914?, And How Many Gallons Is It Supposed Hold
iiibdsiil
post Oct 25 2004, 05:07 PM
Needs Door Locks
When you are pumping your gas, and the thing clicks, do you have to pull the pump head out a couple inches and continue, or am I just retarded? If so, has anyone came up with a remedy for this?
Also, how many gallons it is supposed to hold? I have filled it to the brim before when I wasn't paying attention, I think I got 14 out of it, but it wasn't fully empty. I could be mistaken though.
Hi_Fi_Guy
post Oct 27 2004, 11:05 AM
Tuetonic terror
QUOTE(porschefool @ Oct 26 2004, 07:43 AM)
So THAT'S why my XJ6 smells like gas inside?
I thought it was a fuel line, but couldn't find a leak.
IIRC, last time I filled it up I tried to top 'er off...
Damn.
No smog in my county, guess I'll bypass the canister and see if that helps.
(IMG:style_emoticons/default/dry.gif)
The charcoal cannister is about $700 installed at the dealer. You can buy the part and do it yourself for about 1/2 that. Fixed all fuel-smell problems and the engine ran noticably smoother with a bit lower idle. Plus, the car EASILY passed emissions by a huge margin.
The fuel tank on an XJ-6 is presurized so simply removing or bypassing the cannister may not be a smart option. Check the jag lovers site, I am sure someone there could advise.
best,
iiibdsiil   How Do You Fill Up Your 914?   Oct 25 2004, 05:07 PM
Aaron Cox   IIRC its like 16 gal. yeah, the vapor recovery thi...   Oct 25 2004, 05:10 PM
iiibdsiil   Still haven't gotten the hold of it. I am in m...   Oct 25 2004, 05:13 PM
vsg914   As per owners manual; Tank capacity: 16.4 U.S. gal...   Oct 25 2004, 06:10 PM
!   Just had the same question on the little penis boa...   Oct 25 2004, 06:16 PM
Carlitos Way     Oct 25 2004, 07:21 PM
!   911..... <_<   Oct 25 2004, 07:32 PM
Aaron Cox   <...   Oct 25 2004, 07:34 PM
Joe Ricard   Ah that is too funny. Mississippi ain't got n...   Oct 25 2004, 07:52 PM
Aaron Cox   <...   Oct 25 2004, 08:51 PM
mikerose   Last night On the way home RED lite on Then cough...   Oct 26 2004, 08:53 AM
!   Either you didn't fill it all the way up...or ...   Oct 26 2004, 08:54 AM
mudfoot76     Oct 26 2004, 09:03 AM
Hi_Fi_Guy   Just an FYI. If you are running a 914 with F.I. d...   Oct 26 2004, 09:37 AM
phantom914   <...   Oct 26 2004, 09:38 AM
porschefool   So THAT'S why my XJ6 smells like gas inside? I...   Oct 26 2004, 09:43 AM
ClayPerrine   ...   Oct 27 2004, 07:06 AM
Hi_Fi_Guy
- Lo-Fi Version Time is now: 12th March 2026 - 12:17 AM
