| yellow75 |
Apr 19 2017, 07:19 AM
Member ![]() ![]() Group: Members Posts: 88 Joined: 1-October 16 From: pittsburgh Member No.: 20,452 Region Association: None |
I have been trying to track down a leak in my transaxle. New seal and O ring in speedo angle drive. needed that but it didn't fix the drip.So I cleaned the trans with brake clean and took it out for a drive. Gear oil seems to be coming from the front part of the gearbox where it meets the engine case and coming out the vent hole at the bottom of the bell housing case. Given all that, I'm thinking the input shaft seal is leaking. Am I on the right track? Any other usual suspect places that it could be coming from?
| yellow75 |
Apr 19 2017, 12:40 PM
same as a VW? Is trans removal a one man job?
yellow75 tracking down trans oil leak Apr 19 2017, 07:19 AM
76-914 Yep, your on the right trail. It is easily removed... Apr 19 2017, 08:36 AM
porschetub
E... Apr 19 2017, 02:28 PM
Ferg Depending on how dirty it is source of leak can be... Apr 19 2017, 02:50 PM
saigon71 The leak from the bell housing is most likely the ... Apr 19 2017, 03:38 PM
yellow75 OK you have given me faith. I have good tools and ... Apr 19 2017, 08:10 PM
Dave_Darling Loosen the motor mount bolts, it reduces the strai... Apr 19 2017, 09:47 PM
falcor75
Loosen the motor mount bolts, it reduces the stra... Apr 19 2017, 09:59 PM
euro911 You might contact Mark Heard (914Sixer) to see if ... Apr 19 2017, 10:51 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 09:08 AM |
