| yellow75 |
Apr 19 2017, 07:19 AM
Member ![]() ![]() Group: Members Posts: 88 Joined: 1-October 16 From: pittsburgh Member No.: 20,452 Region Association: None |
I have been trying to track down a leak in my transaxle. New seal and O ring in speedo angle drive. needed that but it didn't fix the drip.So I cleaned the trans with brake clean and took it out for a drive. Gear oil seems to be coming from the front part of the gearbox where it meets the engine case and coming out the vent hole at the bottom of the bell housing case. Given all that, I'm thinking the input shaft seal is leaking. Am I on the right track? Any other usual suspect places that it could be coming from?
| yellow75 |
Apr 19 2017, 12:40 PM
same as a VW? Is trans removal a one man job?
| porschetub |
Apr 19 2017, 02:28 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,064 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
same as a VW? Is trans removal a one man job? Easier than a VW,top starter bolt is a bitch to get at till you drop the trans down a bit before blocking the motor up. Get on to it soon before the leak ruins your clutch disk,make sure you replace the throw out lever cup bush and the sliders for your bearing. I made a wooden base for my jack and strapped the trans to it....then its a one man operation. |
yellow75 tracking down trans oil leak Apr 19 2017, 07:19 AM
76-914 Yep, your on the right trail. It is easily removed... Apr 19 2017, 08:36 AM
Ferg Depending on how dirty it is source of leak can be... Apr 19 2017, 02:50 PM
saigon71 The leak from the bell housing is most likely the ... Apr 19 2017, 03:38 PM
yellow75 OK you have given me faith. I have good tools and ... Apr 19 2017, 08:10 PM
Dave_Darling Loosen the motor mount bolts, it reduces the strai... Apr 19 2017, 09:47 PM
falcor75
Loosen the motor mount bolts, it reduces the stra... Apr 19 2017, 09:59 PM
euro911 You might contact Mark Heard (914Sixer) to see if ... Apr 19 2017, 10:51 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 07:49 AM |
