Creaking sound when turning, steering column/wheel creaks |
jrblackbox |
Apr 21 2017, 09:26 AM
Member Group: Members Posts: 285 Joined: 8-September 15 From: Easton, CT Member No.: 19,140 Region Association: None |
I get an annoying creak when turning the steering wheel. Most noticeably when parking or turning the wheel at low speeds. What can I do to rid my car of this?
Dave_Darling |
Apr 21 2017, 10:56 AM
Is it just from turning the wheel, or from turning the wheel while the car is moving?
If the former, there's something going on with your steering column. Replacing the bushing in the column might work, or cleaning up and re-lubing or loosening and re-positioning the universal joints in the column. If the latter, the tire is likely rubbing on one fender or the other. Fixing that requires changing tires or wheels, or some work with a BFH or roller. --DD |
jrblackbox |
Apr 21 2017, 01:49 PM
Is it just from turning the wheel, or from turning the wheel while the car is moving? If the former, there's something going on with your steering column. Replacing the bushing in the column might work, or cleaning up and re-lubing or loosening and re-positioning the universal joints in the column. If the latter, the tire is likely rubbing on one fender or the other. Fixing that requires changing tires or wheels, or some work with a BFH or roller. --DD It is coming from the column itself. The noise is right there at the column, appears to be up by the steering wheel. |
Lo-Fi Version | Time is now: 15th June 2024 - 11:00 AM |
