where to get reproduction GT oil cooler shroud? |
jmz |
Apr 24 2017, 10:08 AM
Member Group: Members Posts: 165 Joined: 11-April 16 From: Lone Star State Member No.: 19,886 Region Association: None |
I'm trying to dress up my 914/6 GT-spec car a bit and would like stamped copy of the original GT oil cooler shroud. Anyone know where to find one?
jmz |
Apr 24 2017, 03:14 PM
As I look more closely and think about this it may be a bigger project than I had thought.
I think the placement of the fuel cell I have may not allow the factory type oil cooler shroud to even fit.. Thoughts? |
mepstein |
Apr 24 2017, 03:21 PM
914-6 GT in waiting Group: Members Posts: 19,313 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
As I look more closely and think about this it may be a bigger project than I had thought. I think the placement of the fuel cell I have may not allow the factory type oil cooler shroud to even fit.. Thoughts? Correct, It will not. Make a pattern then some galvanized sheet metal from an hvac place - scrap - and cut and bend on a brake and then screw or rivet together. You can paint, powdercoat or leave plain. You can always have a nice one done from aluminum once you know your steel one works. |
jmz |
Apr 24 2017, 03:56 PM
As I look more closely and think about this it may be a bigger project than I had thought. I think the placement of the fuel cell I have may not allow the factory type oil cooler shroud to even fit.. Thoughts? Correct, It will not. Make a pattern then some galvanized sheet metal from an hvac place - scrap - and cut and bend on a brake and then screw or rivet together. You can paint, powdercoat or leave plain. You can always have a nice one done from aluminum once you know your steel one works. Good Call. ...car is so custom anyway as I guess a lot of true and replica GTs are anyway so what the heck. I'll just get busy and fabricate something. |
914_teener |
Apr 24 2017, 04:29 PM
914 Guru Group: Members Posts: 5,205 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
As I look more closely and think about this it may be a bigger project than I had thought. I think the placement of the fuel cell I have may not allow the factory type oil cooler shroud to even fit.. Thoughts? Correct, It will not. Make a pattern then some galvanized sheet metal from an hvac place - scrap - and cut and bend on a brake and then screw or rivet together. You can paint, powdercoat or leave plain. You can always have a nice one done from aluminum once you know your steel one works. Good Call. ...car is so custom anyway as I guess a lot of true and replica GTs are anyway so what the heck. I'll just get busy and fabricate something. If you know how to do triangulation line development on light guage sheet metal then you don.t really need a press brake to form it. You can form it over the edge of a metal workbench or vise for a nice smoth transition shape. Always looks nicer. My two cents for ya. Maybe you already know that. That type of metalworking is a lost art |
mb911 |
Apr 24 2017, 07:40 PM
914 Guru Group: Members Posts: 6,881 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
As I look more closely and think about this it may be a bigger project than I had thought. I think the placement of the fuel cell I have may not allow the factory type oil cooler shroud to even fit.. Thoughts? Correct, It will not. Make a pattern then some galvanized sheet metal from an hvac place - scrap - and cut and bend on a brake and then screw or rivet together. You can paint, powdercoat or leave plain. You can always have a nice one done from aluminum once you know your steel one works. Good Call. ...car is so custom anyway as I guess a lot of true and replica GTs are anyway so what the heck. I'll just get busy and fabricate something. If you know how to do triangulation line development on light guage sheet metal then you don.t really need a press brake to form it. You can form it over the edge of a metal workbench or vise for a nice smoth transition shape. Always looks nicer. My two cents for ya. Maybe you already know that. That type of metalworking is a lost art We teach how to do that where I teach welding. |
Lo-Fi Version | Time is now: 7th June 2024 - 05:13 PM |
