| machina |
Oct 27 2004, 11:50 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Benefactors Posts: 2,030 Joined: 21-June 03 From: Miami Beach, FL Member No.: 848 |
Just about ready to crank her over, does it matter how the breather lines are plumbed?
For example, should the lines from each head come together and then go to the catch tank while the line from the oil tower joins at the end of that run? Or is it OK if the right head breather line connects T's to the oil tower breather and then get t'd to the left head breather and to the tank? After this I just have to bolt up the header and countdown. |
| machina |
Oct 27 2004, 07:42 PM
Here's a couple pics of my rig. The catch tank is in the trunk and plumbed back thru the firewall. The drain for the tank is actually under the floor of the trunk. Looks neat and when its time to drain the oil, won't mess up the engine bay or trunk.
I may change the routing of the breather lines later, right now I just wanted to get her fired. Attached image(s)
synthesisdv breather line routing Oct 27 2004, 11:50 AM
SirAndy the heads "suck" at higher rpms and the oil-filler... Oct 27 2004, 12:06 PM
ein 6er dr,
moroso this weekend? i think i'm going o... Oct 27 2004, 04:52 PM
VegasRacer Andys looks pretty much the same way as mine is do... Oct 27 2004, 06:28 PM
synthesisdv <... Oct 27 2004, 06:58 PM![]() ![]() |
Lo-Fi Version | Time is now: 29th April 2026 - 07:59 PM |
