Got tired of holding the gas pump nozzle.., Easy fix |
oakdalecurtis |
Apr 28 2017, 08:08 PM
Oakdalecurtis Group: Members Posts: 1,329 Joined: 5-June 15 From: Oakdale, Ca Member No.: 18,802 Region Association: Central California |
While refueling my 914 for the last 20 years, I have had to hold the gas pump nozzle anti vapor ring up while pumping the gas in because the pump nozzles don't go into the tank far enough. I finally cut a ring of tubing (almost any kind will work) and attached it with a chain near the tank. Here's a pic of the ring and attachment, how it goes on the tank, and the pump in it. The inside diameter of the ring must be greater than 1 5/8 inches and no larger OD than 2 1/2 inches, and the length should be between 1/2 and 5/8 of an inch to space the pump nozzle properly. It's so nice to put the nozzle in now and click it on till the tank is full!
Mike Bellis |
Apr 30 2017, 09:18 AM
Resident Electrician Group: Members Posts: 8,345 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None |
I don't drive mine enough for this to bother me. Problem is the automatic shut off will kick in when the tank reaches around 10 gallons. Then I have to pull back the vapor recovery corrugated part to top off the tank. Right no I do this 3-4 times a year (at my present rate of use).
I think this is neat and corny at the same time... |
stevend914 |
Apr 30 2017, 09:30 AM
Member Group: Members Posts: 376 Joined: 13-December 16 From: Saint Louis Member No.: 20,670 Region Association: Upper MidWest |
I don't drive mine enough for this to bother me. Problem is the automatic shut off will kick in when the tank reaches around 10 gallons. Then I have to pull back the vapor recovery corrugated part to top off the tank. Right no I do this 3-4 times a year (at my present rate of use). I think this is neat and corny at the same time... I filled up 16 times from March 22 thru April 8 and expect the same in May/June when I go to NM/WCR/CO. |
Lo-Fi Version | Time is now: 16th June 2024 - 07:37 AM |
