> Fuel smell, Fuel smell
bam1957
post May 1 2017, 07:37 PM
Region Association: Middle East
I had a 914 in 1985 and I don't remember having any issues with a gas smell inside the car. I'm in the market now and have test driven two cars in the past two months. While test driving them I have noticed a strong smell of gas inside the car during the drive. Can anyone tell me if this a normal caracteristic of the 914 after 40 years and do you experience the same thing or can anyone tell me what they think might be wrong with the cars I have checked out? Thanks
Amphicar770
post May 2 2017, 08:08 PM
You should not smell fuel but also do not assume it is just a fuel cap gasket if you do. Mine had similar issues. Resolved only after I replaced all the lines front to back. I had my tank cleaned and treated and the also discovered some pinholes that they brazed up. This on about as rust free a car as you will find. I also replaced the 40 year old activated charcoal at the same time, you can open up canister to do so.
bam1957   Fuel smell   May 1 2017, 07:37 PM
snakemain   Could be a case of FI vs carbs (carbs have gas ven...   May 1 2017, 08:16 PM
bam1957   Could be a case of FI vs carbs (carbs have gas ve...   May 1 2017, 08:22 PM
mark04usa   Replacing fuel hoses and lines is a regular mainte...   May 1 2017, 08:24 PM
bam1957   I'm just hoping that they are all not like tha...   May 1 2017, 08:26 PM
bam1957   Thanks   May 1 2017, 08:27 PM
bam1957   I'll keep an eye out for that and also ask the...   May 1 2017, 08:32 PM
jmalone   The easiest explanation would be spilled fuel in t...   May 1 2017, 08:43 PM
zipedadoo   My car had a strong gas smell, finally realized it...   May 1 2017, 08:51 PM
Coondog   Doesn't matter if you buy a 914 change all the...   May 1 2017, 08:51 PM
Tastyplacement   Not a big deal at all...that gas cap gasket is lik...   May 1 2017, 08:56 PM
GregAmy   The fuel smell in my '74 purchase was a fuel t...   May 1 2017, 08:59 PM
cuddyk   The short answer is no...914s shouldn't have a...   May 1 2017, 09:04 PM
Larmo63   It is a common issue with these cars. There are nu...   May 1 2017, 09:54 PM
bam1957   Thank you all for the info, you've been very h...   May 1 2017, 10:32 PM
JawjaPorsche   914Rubber sells gas cap gaskets.   May 2 2017, 03:50 AM
Amphicar770   You should not smell fuel but also do not assume i...   May 2 2017, 08:08 PM
branston   The cabin on my FI 914 started to stink of gas. ...   May 2 2017, 08:15 PM
mepstein   Fuel lines under the tank, in the tunnel, on the e...   May 2 2017, 08:33 PM
bam1957   Thanks again to everyone!   May 3 2017, 07:51 AM
- Lo-Fi Version Time is now: 1st July 2025 - 11:09 AM
