GB Euro style front turn signal lenses $48, 10 days only ends May 10th LAST day Today!!!!! |
Mikey914 |
May 1 2017, 03:41 PM
The rubber man Group: Members Posts: 12,678 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Listing is live now!
Euro Lens set Use code Euro48 at checkout to receive the group buy pricing. We have posted up a few pictures of these and at $48 a set we aren't making much, but since we posted we would do them on GB here's your chance. If you are in bump the thread and We will give you the code. We will have these in the future at $68 a set. So who's' in? These will be a pre buy with about 1 week lead time so these are not in stock, but will have for you shortly. Mark Attached thumbnail(s) Attached image(s) |
brownaar |
May 2 2017, 10:21 AM
Member Group: Members Posts: 263 Joined: 23-September 04 From: Gate City, VA Member No.: 2,813 Region Association: None |
Are these "cut and paste" like mentioned in the other thread. As opposed to 2-color injection molding. I know you mentioned that would be quite a bit more expensive to produce.
Mikey914 |
May 3 2017, 09:24 AM
Are these "cut and paste" like mentioned in the other thread. As opposed to 2-color injection molding. I know you mentioned that would be quite a bit more expensive to produce. These are. They require more labor to produce, but are quite nice. Attached is a close up. Attached image(s) |
BillC |
May 3 2017, 03:42 PM
Senior Member Group: Members Posts: 546 Joined: 24-April 15 From: Silver Spring, MD Member No.: 18,667 Region Association: MidAtlantic Region |
Are these "cut and paste" like mentioned in the other thread. As opposed to 2-color injection molding. I know you mentioned that would be quite a bit more expensive to produce. These are. They require more labor to produce, but are quite nice. Attached is a close up. What glue do you use to attach the two parts? I have a rear taillight lens where the clear reverse light portion detached from the orange portion at the seam. I'd like to glue them back together, but not sure what to use. Was actually thinking about using Testor's model glue. |
mepstein |
May 3 2017, 07:09 PM
914-6 GT in waiting Group: Members Posts: 19,313 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Are these "cut and paste" like mentioned in the other thread. As opposed to 2-color injection molding. I know you mentioned that would be quite a bit more expensive to produce. These are. They require more labor to produce, but are quite nice. Attached is a close up. What glue do you use to attach the two parts? I have a rear taillight lens where the clear reverse light portion detached from the orange portion at the seam. I'd like to glue them back together, but not sure what to use. Was actually thinking about using Testor's model glue. Use superglue. |
Lo-Fi Version | Time is now: 8th June 2024 - 09:09 AM |
