options for first start - oil priming |
Optimusglen |
May 5 2017, 07:40 AM
Senior Member Group: Members Posts: 912 Joined: 26-February 16 From: Minneapolis Member No.: 19,709 Region Association: Upper MidWest |
Hey all, my project is coming along and this weekend I will probably try the first start.
It was a rebuild down to the shortblock, 1911 with dual Webers. I've heard of a few methods for priming the oil chambers and wanted to see if there was a preferred method you guys use. Option 1: disconnect fuel pump and just crank it over until the oil pressure light goes out. Option 2: disconnect fuel pump and remove spark plugs and valve rocker assemblies to reduce load on the starter and crank. Turn over until oil pressure light goes out. Option 3: fabricate an oil can that can take air pressure, hose comes out and connected to where the oil pressure switch goes. Pressurize the can and push 2 qts into the engine, add the rest of the oil to the filler. Any other methods? |
TheCabinetmaker |
May 5 2017, 08:17 AM
I drive my car everyday Group: Members Posts: 8,304 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
Does down to the short block mean you did not split the case? I hate to guess.
Optimusglen |
May 5 2017, 08:22 AM
Lo-Fi Version | Time is now: 16th June 2024 - 11:18 AM |
