Temp sensor, Out of production? |
Tjmrfe |
May 7 2017, 07:15 AM
NON IMPEDING RATIONE COGITATIONIS Group: Members Posts: 132 Joined: 10-April 15 From: Cornwall on Hudson, New York Member No.: 18,612 Region Association: North East States |
Hello guys,
My 75' 1.8 needs a new oil temperature sender...so I try AA, they only list a different size, (shorter rod) & it's a 300 degrees unit, mine clearly says 200 degrees. It's a VDO So I look @ Pelican and all the other sites, including eBay (IMG:style_emoticons/default/mad.gif) and all are 300's which seem to be for the 6.... So, any ideas where I might find one? Or why all the ones I do find are 300's, do they not make them? I believe my gauge is set for 200. It's the VDO, non-numerical style with the red zone... Thanks... |
McMark |
May 7 2017, 07:51 AM
I've never seen one go bad. Try a different used one. Also make sure there's an electrical path for the sensor to ground. If you refinished the mounting plate, you may have eliminated the ground path.
Lo-Fi Version | Time is now: 9th June 2024 - 05:16 AM |
