MPS reinstall |
MPS reinstall |
87m491 |
May 7 2017, 02:29 PM
Member Group: Members Posts: 275 Joined: 29-July 12 From: Portland, the original! Member No.: 14,731 Region Association: North East States |
Have just done the whole soft fuel system soup to nuts and I am buttoning up the engine compartment. I went to remount the MPS and the service port on the fuel rail is hitting the MPS body dead center.
(IMG:http://www.914world.com/bbs2/uploads_offsite/i723.photobucket.com-14731-1494188982.1.jpg) The fuel elbows to the injectors are new and not as pliable as the originals, though a fair bit shorter so any interference should have been less than with the originals. Any one else run into this? Tilting the rail forward or back does not seem to help much as this port hits right in the widest portion of the MPS. Now I know why them MPS only had the top bolt properly installed and sheet metal screws in the bottom two holes. |
87m491 |
May 7 2017, 03:59 PM
Whoa, that is one busy engine compartment with FP regulator and MPS on the same side. To be clear on my car the test port is factory blocked off AFAIK. Car is a 74 2.0. The port on the drivers side rail is open and feeds the cold start injector. Might be worthwhile to find a VW unit with no port at all to grab 10mm of space.
914_teener |
May 7 2017, 04:20 PM
914 Guru Group: Members Posts: 5,201 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
Whoa, that is one busy engine compartment with FP regulator and MPS on the same side. To be clear on my car the test port is factory blocked off AFAIK. Car is a 74 2.0. The port on the drivers side rail is open and feeds the cold start injector. Might be worthwhile to find a VW unit with no port at all to grab 10mm of space. FP regulator is on the driver side in the pic I posted it is on the right side. |
Lo-Fi Version | Time is now: 1st June 2024 - 01:31 PM |
