| steuspeed |
May 5 2017, 09:42 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,011 Joined: 12-July 11 From: Portland, Oregon Member No.: 13,308 Region Association: Pacific Northwest |
Installed Hella supertone horns. Plug and play. They came with a relay. I did not use it. Maybe install later?
Attached thumbnail(s) |
| oakdalecurtis |
May 8 2017, 10:13 PM
Oakdalecurtis ![]() ![]() ![]() Group: Members Posts: 1,403 Joined: 5-June 15 From: Oakdale, Ca Member No.: 18,802 Region Association: Central California
The stock horn already has a relay, why would a second relay be necessary? If the wire to the factory horn is too light, couldn't you just increase that wire from the existing relay to the new horns?
| VaccaRabite |
May 9 2017, 09:42 AM
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,845 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region
The stock horn already has a relay, why would a second relay be necessary? If the wire to the factory horn is too light, couldn't you just increase that wire from the existing relay to the new horns? You could, and maybe it would work just fine. But it does not run to the battery directly (IIRC), and that would be a lot of harness unwrapping to get to the wire in question. Its a LOT easier to just run a new wire, and a lot easier to pull that wire out if you want to go back to stock later. Zach |
steuspeed Intsalled Hella Supertone horns. May 5 2017, 09:42 PM
ConeDodger I have a set that I need to install as well. The h... May 5 2017, 10:25 PM
914dave They are loud! 118 decibels. I thought mine wa... May 6 2017, 06:12 AM
Tjmrfe
They are loud! 118 decibels. I thought mine w... May 6 2017, 08:13 AM
GeorgeRud I put some on my 911, and am very impressed with t... May 6 2017, 07:08 AM
steuspeed
I put some on my 911, and am very impressed with ... May 14 2017, 01:25 AM
Olympic 1.7 I got a set of the Hella Sharptones. haven't ... May 6 2017, 08:50 AM
Philip W. I also bought these last month but I have not inst... May 6 2017, 10:17 AM
orthobiz I assume they fit under the grilles....???
Paul May 6 2017, 02:22 PM
ConeDodger
Paul
... May 6 2017, 04:58 PM
914dave
Paul
... May 7 2017, 07:31 AM
jim_hoyland Are these Hellas made in Germany ? May 6 2017, 05:11 PM
GeorgeRud I don't think so anymore. There is a YouTube ... May 6 2017, 07:23 PM
Vacca Rabite Use the relay!
Cant stress this enough.
I put ... May 8 2017, 09:29 AM
Philip W.
Use the relay!
I put... May 8 2017, 10:10 AM
Vacca Rabite http://www.914world.com/bbs2/uploads_offsite/c2.st... May 8 2017, 09:02 PM
Philip W. put mine in today! passenger side was easy, pl... May 10 2017, 08:32 PM
McMark :rotfl: I had a dream about this thread last nigh... May 11 2017, 07:05 AM
LowBridge I have mine mounted behind the 75 bumper without a... May 11 2017, 08:05 AM![]() ![]() |
Lo-Fi Version | Time is now: 27th March 2026 - 04:29 AM |
