| GeorgeRud |
Feb 28 2017, 05:10 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,725 Joined: 27-July 05 From: Chicagoland Member No.: 4,482 Region Association: Upper MidWest |
I was wondering if anyone has swapped out the original 35w bulb in the early round (worthless) fog lights for some LEDs? It should make a nice option and could be used as daytime running lights to help defend ourselves against today's brain dead drivers.
BTW, does anyone else have trouble with the search function giving too many results that don't seem to be relavent? |
| rgolia |
Mar 1 2017, 01:54 PM
GeoJoe ![]() ![]() ![]() Group: Members Posts: 721 Joined: 5-February 10 From: PA Member No.: 11,329 Region Association: North East States
Maybe spoke would be willing to make these up for those of us with poor eyesight and poor soldering skills. I have Spokes led lights as well. Should we PM Jerry?
| Spoke |
May 12 2017, 11:50 AM
Jerry ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,429 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None
Maybe spoke would be willing to make these up for those of us with poor eyesight and poor soldering skills. I have Spokes led lights as well. Should we PM Jerry? Ralph, thanks for thinking about me. I've shied away from these high power applications since they involve expensive LEDs and heatsinking like the worklight from Amazon mentioned earlier in this thread. The boards I've done would be classified as "indicator lamp replacements" versus high power beams. The Amazon worklight burns 27W whereas my 914 brake boards burn less than 5W. A difference between my boards and items like headlight and fog light is the beam. Turnsignals and brake lights should throw light in all directions which is why many lenses and reflectors have dimples and other diamond patterns. Headlights and foglights need to be shaped beams such that they have good horizontal dispersion and a tight cutoff upwards as to not blind oncoming drivers. For example the worklight mentioned has a 30 degree beam dispersion. This parameter usually means 30 degree is the 1/2 light energy angle. So if the light is mounted horizontally, the 1/2 power angle is 15 degrees upwards and downwards. If these are very bright they may blind oncoming drivers. I've seen a couple of trucks with large white LED panel mounted on the front of the cab. These were extremely bright and not a focused beam. I would imagine they may be illegal used as a forward light on a vehicle. The LED panel is likely targeted for general lighting and not for forward vehicle lighting. ![]() |
GeorgeRud Fog light led conversion Feb 28 2017, 05:10 PM
rgolia I thought someone looked into this. I think the r... Feb 28 2017, 05:25 PM
jkb944t I was interested in this too but that bulb has an ... Feb 28 2017, 08:28 PM
pbanders These are $22 for a pair, fit into the standa... Feb 28 2017, 10:11 PM
mramber
These are $22 for a pair, fit into the stand... Mar 1 2017, 08:52 AM
pbanders
[quote name='pbanders' post='2459400' date='Feb 2... Mar 1 2017, 05:40 PM
mramber
[quote name='pbanders' post='2459400' date='Feb ... Mar 3 2017, 05:13 PM
pbanders
[quote name='pbanders' post='2459656' date='Mar 1... Mar 3 2017, 08:47 PM
SKL1 Hmmm, PHX area? I'll look for you if you... Feb 28 2017, 11:02 PM
Firstcar George (OP),
I wanted my freshly restored fog lig... Mar 1 2017, 11:13 AM
rgolia Firstcar...thanks for the info, i am going to give... Mar 1 2017, 12:55 PM
GeorgeRud Thanks, I was hoping someone may have found some r... Mar 1 2017, 01:04 PM
Firstcar Here's a shot with the lamps off. You can jus... Mar 1 2017, 01:30 PM
Here's a shot with the lamps off. You can ju... Mar 1 2017, 01:51 PM
Biggles
Here's a shot with the lamps off. You can ju... May 11 2017, 03:15 PM
rgolia
[quote name='rgolia' post='2459597' date='Mar 1 2... May 12 2017, 02:26 PM
porsche913b_sp :popcorn: May 11 2017, 04:22 PM
Firstcar Chris,
I think you have a different foglight than ... May 11 2017, 05:10 PM
anderssj Chris,
Your light might be a slightly different v... May 11 2017, 06:23 PM
Biggles Steve/Scott
Thanks for your replies. That makes t... May 12 2017, 01:34 AM
87m491 Just Google H3 LED bulbs. I am sure you'll f... May 12 2017, 04:29 AM
Biggles Great thanks, the fog has lifted!
Just Goo... May 12 2017, 12:24 PM
morgan_harwell The fog lights in my 914 use Halogen H2 bulbs.
Has... May 12 2017, 08:00 AM
anderssj
Ha... May 12 2017, 08:24 AM
StarBear Was wondering - has anyone tried this (motorcycle ... Jul 21 2022, 03:18 PM
jdamiano I haven’t used those but if you want really nice... Jul 21 2022, 06:57 PM
StarBear
I haven’t used those but if you want really nic... Jul 21 2022, 08:15 PM![]() ![]() |
Lo-Fi Version | Time is now: 23rd September 2026 - 08:02 PM |
