| capitolatim |
May 21 2017, 05:53 PM
Member ![]() ![]() Group: Members Posts: 64 Joined: 11-June 15 From: capitola,ca Member No.: 18,841 Region Association: Northern California |
| oakdalecurtis |
May 21 2017, 08:15 PM
Oakdalecurtis ![]() ![]() ![]() Group: Members Posts: 1,407 Joined: 5-June 15 From: Oakdale, Ca Member No.: 18,802 Region Association: Central California
I would be concerned that in your picture, the wire from your horn relay to your horn button is red. On my car and on the Pelican wiring diagram, the wire from the horn button, H, to the horn relay, J4, is shown as brown with a white stripe . What color is the wire at pin 85 on your horn relay, should be brown with white stripe? If it's the same red as at your wheel, check it's continuity to the horn button. If that wire is correct, then check continuity on the black wire with yellow stripe that goes from the pin 87 on the horn relay to power the horn. The brown wire on the horn itself is ground.
capitolatim Horn Problem May 21 2017, 05:53 PM
914Sixer Bad horn. May 21 2017, 06:20 PM
capitolatim No horn tests good, and the new horn didn't wo... May 21 2017, 06:36 PM
Rand He said horn tests good on battery. Has to be wiri... May 21 2017, 06:39 PM
capitolatim
I would be concerned that in your picture, the wi... May 22 2017, 09:04 AM
r_towle I believe its a grounding issue behind he wheel.
T... May 21 2017, 09:50 PM
porschetub
... May 21 2017, 10:49 PM
capitolatim
I believe its a grounding issue behind he wheel.... May 22 2017, 09:07 AM
Dave_Darling Up through 72 or 73 the horn does not have a relay... May 22 2017, 11:12 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 01:43 PM |
