Brand New Weber 44 Leaking! |
MikeM |
May 20 2017, 08:17 PM
Senior Member Group: Members Posts: 564 Joined: 16-May 10 From: Calgary, Canada Member No.: 11,733 Region Association: Canada |
Hi all...
Last fall I bought and installed new made in Spain Weber 44's. I have driven maybe 50 miles since installation. Today after I drive I smelled and noticed a fuel leak. Fuel was dripping off the accelerator pump adjustment rod under the diaphram housing. It was not coming from the housing itself but from under it, in the middle of the 2 barrels . It was a pretty good drip that started several minutes after shutting off the engine. It does not appear to leak with the engine running. All I've done recently is installed larger idle jets and installed the rotary fuel pump from CB Performance. Any and all help and advice appreciated. Thanks. Mike |
falcor75 |
May 22 2017, 12:47 AM
Senior Member Group: Members Posts: 1,579 Joined: 22-November 12 From: Sweden Member No.: 15,176 Region Association: Scandinavia |
You can order the insulators from a dealership too, not terrible expensive.
Lo-Fi Version | Time is now: 10th June 2024 - 04:13 AM |
