Brand New Weber 44 Leaking! |
MikeM |
May 20 2017, 08:17 PM
Senior Member Group: Members Posts: 564 Joined: 16-May 10 From: Calgary, Canada Member No.: 11,733 Region Association: Canada |
Hi all...
Last fall I bought and installed new made in Spain Weber 44's. I have driven maybe 50 miles since installation. Today after I drive I smelled and noticed a fuel leak. Fuel was dripping off the accelerator pump adjustment rod under the diaphram housing. It was not coming from the housing itself but from under it, in the middle of the 2 barrels . It was a pretty good drip that started several minutes after shutting off the engine. It does not appear to leak with the engine running. All I've done recently is installed larger idle jets and installed the rotary fuel pump from CB Performance. Any and all help and advice appreciated. Thanks. Mike |
r_towle |
May 21 2017, 09:40 PM
Custom Member Group: Members Posts: 24,591 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
boiling can happen.
Do you have phenolic spacers between the heads and intake manifold or the manifolds and carbs? You need some sort of thermal break there and they may not have come wth your kit. they are black and look like plastic, are about 1/8 inch thick. Rich |
MikeM |
May 22 2017, 09:12 AM
boiling can happen. Do you have phenolic spacers between the heads and intake manifold or the manifolds and carbs? You need some sort of thermal break there and they may not have come wth your kit. they are black and look like plastic, are about 1/8 inch thick. Rich Hi Rich...Found them at aircooled.net. They are 2 to 3 mm thick. Is this adequate? Much more the that and I'll need to change the studs on the intake manifold. Thanks |
Lo-Fi Version | Time is now: 10th June 2024 - 02:11 PM |
