Yes, it's true., Thanks to Dave Darling |
Porschef |
May 23 2017, 06:55 PM
How you doin' Group: Members Posts: 2,165 Joined: 7-September 10 From: LawnGuyland Member No.: 12,152 Region Association: North East States |
You can indeed, remove ALL the push rod tubes without dropping/lowering the engine. Did it this past weekend. The key is to remove the tubes and the rods together in any place where the rod alone would hit the console.
Yes, I did use a sealant during replacement, non hardening, as the tube's seals that I removed were pretty much done. A stiff breeze would have blown them out of their bores. I'll check them out this weekend, as I want to change the oil. On the track to eliminate oil leaks, if that is possible... (IMG:style_emoticons/default/dry.gif) Thanks to injunmort for the use of the lift. Very productive weekend. (IMG:style_emoticons/default/biggrin.gif) |
iankarr |
May 23 2017, 07:56 PM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,480 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
Fun meeting you guys. Great hang.
Rand |
May 23 2017, 08:03 PM
Cross Member Group: Members Posts: 7,409 Joined: 8-February 05 From: OR Member No.: 3,573 Region Association: None |
That's a truly awesome rep of 914 guys. (IMG:style_emoticons/default/beerchug.gif)
Lo-Fi Version | Time is now: 1st June 2024 - 06:00 PM |
