| 914Sixer |
Apr 14 2017, 06:35 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,562 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region
Bare,three stud, oval port 2.0 Liter Heads. Just got the email about these a few minutes ago. Says they are in stock and ready to ship $279. Part # 004 CH 039 BC Link not working right.
Attached File(s)
AA_Bare_2.0L_Porsche_914_Casting_3_stud__Round__Port___AA_Performance_Products.htm ( 75.65k )
Number of downloads: 403 |
| 914work |
Apr 27 2017, 04:35 PM
Member ![]() ![]() Group: Members Posts: 291 Joined: 9-November 11 Member No.: 13,762 Region Association: None |
Agreed thanks Len! and a question..
Ive been debating buying a set of AMC heads and engaging in some serious machine work to mod them to 2L spec and twin plug for my 2366 Mtr build w/Nikkies. Do you think these would be acceptable options while perhaps saving me some scratch? |
| HAM Inc |
Apr 27 2017, 06:17 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 850 Joined: 24-July 06 From: Watkinsville,GA Member No.: 6,499 Region Association: None |
Agreed thanks Len! and a question.. Ive been debating buying a set of AMC heads and engaging in some serious machine work to mod them to 2L spec and twin plug for my 2366 Mtr build w/Nikkies. Do you think these would be acceptable options while perhaps saving me some scratch? Verdicts still out on these castings. They make a good first impression, but at this point I need to work a pair. They clearly aren't as beefy as the amc's. The amc's are very good castings that have proven durable on a lot of very high output large displacement engines over the past 15 years. We'll see. Like I said, once I machine a pair I'll know a lot more. I would LOVE it if I didn't have to weld heads to move the spark plugs anymore. I still do all of the welding and peening personally and it takes it's toll physically. Not to mention the time. |
| Robnxious |
May 25 2017, 09:17 PM
RobnxiousOne ![]() ![]() Group: Members Posts: 184 Joined: 26-October 06 From: Sacramento Member No.: 7,097 Region Association: Northern California |
Agreed thanks Len! and a question.. Ive been debating buying a set of AMC heads and engaging in some serious machine work to mod them to 2L spec and twin plug for my 2366 Mtr build w/Nikkies. Do you think these would be acceptable options while perhaps saving me some scratch? Verdicts still out on these castings. They make a good first impression, but at this point I need to work a pair. They clearly aren't as beefy as the amc's. The amc's are very good castings that have proven durable on a lot of very high output large displacement engines over the past 15 years. We'll see. Like I said, once I machine a pair I'll know a lot more. I would LOVE it if I didn't have to weld heads to move the spark plugs anymore. I still do all of the welding and peening personally and it takes it's toll physically. Not to mention the time. Well I for one want to thank you for personally doing the welding and peening on your heads, since my set just arrived for my build today. Can't wait to drive them and see what all the fuss is about! (IMG:style_emoticons/default/drooley.gif) |
| HAM Inc |
May 26 2017, 04:10 PM
Agreed thanks Len! and a question.. Ive been debating buying a set of AMC heads and engaging in some serious machine work to mod them to 2L spec and twin plug for my 2366 Mtr build w/Nikkies. Do you think these would be acceptable options while perhaps saving me some scratch? Verdicts still out on these castings. They make a good first impression, but at this point I need to work a pair. They clearly aren't as beefy as the amc's. The amc's are very good castings that have proven durable on a lot of very high output large displacement engines over the past 15 years. We'll see. Like I said, once I machine a pair I'll know a lot more. I would LOVE it if I didn't have to weld heads to move the spark plugs anymore. I still do all of the welding and peening personally and it takes it's toll physically. Not to mention the time. Well I for one want to thank you for personally doing the welding and peening on your heads, since my set just arrived for my build today. Can't wait to drive them and see what all the fuss is about! (IMG:style_emoticons/default/drooley.gif) Thanks for purchasing a pair of my heads! Lot of time and effort goes into them. Hope you're satisfied with the performance. (IMG:style_emoticons/default/beer.gif) As for the knockoff heads, I've just finished a pair. They machined well and critical deminsions are a match, for the most part. The pushrod tube bores are a couple of thousanths small, which is good since the machine work to them is rough as a cob and require honing to smooth them out so they don't tear o-rings. The flycut finish is okay, but the work from chamber to chamber varied by a couple of thousanths. Our finish work is with .0005" The intake ports are awful as delivered. Rough as cobs (and I like rough, but this was a bit much) and don't line up at all with a factory gasket. But that wasn't a big deal for me as they do have the same corkscrew shape, and are undersized such that with port work they lined up fine and flowed the same as our ported heads. The exhaust ports are pretty much dead nuts copies of the O.E. heads in rough shape and after polishing and blending flow about the same as an untouched stock port, which is good when comparing to other O.E. T4 heads (1.7&1.8) but bad when comparing to what we get out of our AMC heads, which have tiny ports as delivered from AMC and lots of meat around the outside of the port that allows us to carve a far superior shape that we've developed over the years. There's not much that can be done to improve the knockoff ports as they are bulged out where it doesn't help and don't have meat enough to port where it does help. As for the machining characteristics of the heads I ran them on the cnc at the same feeds and speeds with the same tooling as we use on AMC heads. The chips and machined surfaces were identical in appearance to the AMC heads and the machined dimensions were with .0002" of what we get with the AMC's. That tells me that they at least have similar machinibility, which is encouraging regarding alloy characteristics, but hardly conclusive in predicting durability. Because they are lightweight castings of an unknown alloy I am sending this pair off for thermal coatings. After which they will go on a 2270 being built by a freind of mine and Jake's for some serious road use. Not screaming high revver, which would actually be less challenging, but in a 412 that is going to be lugged to the ends of the earth, something aircooled heads hate! My verdict is still out on these castings as far as durability goes. My hunch is that they are going to do at least as well as a 40Y.O. casting that's been run through the ringer. That said, I'm willing to build them out with quality parts if people are interested, but I'm not willing to put any[i] warranty on them beyond my workmanship. |
914Sixer New Bare 039 Heads Available $279 Apr 14 2017, 06:35 PM
Mueller Wonder if they are AMC based casting or someone ne... Apr 14 2017, 07:37 PM
Java2570 Don't see it on their website yet but everythi... Apr 15 2017, 07:53 AM
poorsche914 Here's a link 914 Heads
:driving: Apr 15 2017, 10:27 AM
Mark Henry That is a good deal, but it is bare no guides and ... Apr 15 2017, 11:55 AM
PotterPorsche I wonder if there AMC or a new casting. I'm s... Apr 15 2017, 05:08 PM
Mueller So tempting to buy a set with that 15% off discoun... Apr 15 2017, 08:03 PM
lonewolfe I got that email too! I don't believe thes... Apr 15 2017, 11:48 PM
drgouk Im pretty sure that they are 2.0 plug location, lo... Apr 16 2017, 01:40 AM
McMark I'm gonna order a set tomorrow. :idea: Apr 16 2017, 06:29 AM
Krieger
Mar... Apr 16 2017, 08:02 AM
brownaar
:agree: Apr 16 2017, 03:42 PM
Jake Raby I'll order a set and see what happens when the... Apr 16 2017, 04:09 PM
Rocky
I'll order a set and see what happens when th... Apr 16 2017, 05:19 PM
r_towle
I'll order a set and see what happens when th... Apr 16 2017, 06:18 PM
HAM Inc Pretty sure they're not Spanish AMC's at t... Apr 16 2017, 05:36 PM
PotterPorsche From a head porter perspective, on a set of non st... Apr 16 2017, 05:47 PM
HAM Inc
From a head porter perspective, on a set of non s... Apr 16 2017, 05:57 PM
PotterPorsche Not sure if I undertand the question, but if you m... Apr 16 2017, 06:39 PM
Mueller So who has placed an order for these?
Anyone wan... Apr 20 2017, 11:35 AM
McMark Just placed mine. These aren't AMC. AA took ... Apr 20 2017, 01:24 PM
Kansas 914
Just placed mine. These aren't AMC. AA took... Apr 20 2017, 02:46 PM
Racer Chris
Just placed mine. These aren't AMC. AA took... Apr 20 2017, 03:07 PM
Mueller Wonder if they will make some /6 heads now! Apr 26 2017, 01:33 PM
dansvan So they come with valve seats? Or pockets for valv... Apr 26 2017, 01:42 PM
McMark Pockets. You can order them complete, but who mak... Apr 26 2017, 02:02 PM
CMONNETT I'm curious how good these are. I'm half ... Apr 27 2017, 12:34 PM
Kansas 914
I'm curious how good these are. I'm half... Apr 27 2017, 12:37 PM
Mueller
I'm curious how good these are. I'm half... Apr 27 2017, 12:38 PM
bretth I recently saw a company selling type VW (edit typ... Apr 27 2017, 12:56 PM
McMark
[quote name='CMONNETT' post='2480092' date='Apr 2... Apr 27 2017, 01:12 PM
Kansas 914 This is all very encouraging. Thanks Mark. Apr 27 2017, 01:20 PM
McMark Click the pictures for the full size versions if y... Apr 27 2017, 01:24 PM
Mueller Nice, thanks for posting.
Are you going to instal... Apr 27 2017, 01:31 PM
Mark Henry I think I'm going to have to get a set.
Nice... Apr 27 2017, 02:48 PM
rdauenhauer notice the CHT location isnt drilled/tapped either... Apr 27 2017, 02:55 PM
HAM Inc Overall they don't look bad at all for a first... Apr 27 2017, 03:42 PM
Kansas 914
Overall they don't look bad at all for a firs... Apr 27 2017, 03:45 PM
Frank S My verdict is still out on these castings as far a... Jul 18 2017, 06:31 AM
brownaar Any new progress/updates on this? May 25 2017, 06:44 PM
Krieger Thanks for your analysis Len! :beer1: May 26 2017, 04:21 PM
914Sixer Len's verdict is good to hear. He mentioned i... May 26 2017, 08:25 PM
Mueller
Len's verdict is good to hear. He mentioned ... Jun 15 2017, 12:22 PM
gothspeed EDIT: please disregard this post and bump!... Jan 26 2018, 02:17 PM
FUEL14 I'm just :bump: ing this thread to see if the... Sep 15 2018, 05:38 AM
HAM Inc
I'm just :bump: ing this thread to see if th... Sep 15 2018, 07:59 AM
FUEL14 Len, thanks so much for the indepth reply. What... Sep 15 2018, 09:24 PM
HAM Inc
Len, thanks so much for the indepth reply. What... Sep 16 2018, 08:35 AM
McMark :agree: Len is far more intimate with heads than ... Sep 16 2018, 12:44 PM
Jetsetsurfshop First, thanks Len for the heads. :beer2:
Here... Sep 16 2018, 02:21 PM
FUEL14 Awesome... Thanks for sharing this information.
... Sep 18 2018, 05:17 AM![]() ![]() |
Lo-Fi Version | Time is now: 12th September 2026 - 08:36 AM |
