The best location for an electric water pump SBC V8 conversion, The best location for an electric water pump SBC V8 conversion |
BRAVE_HELIOS |
Apr 22 2017, 10:06 AM
"Knowledge speaks, wisdom listens" Group: Members Posts: 295 Joined: 25-September 06 From: The Land Of ID! Member No.: 6,920 Region Association: Pacific Northwest |
Hey all,
Inching closer to going electric on my V8 conversion car. Right now; going through the process of cleaning out radiator and water passages/block with ThermoCure, then Prestone citric acid flush. Assuming I get a really clean system but not fix the run hot situation; I will go electric. Where is the best place to mount the electric pump? It would seem that the easiest way to go in my case is with this: http://www.jegs.com/i/JEGS-Performance-Pro.../50930/10002/-1 It a 50 GPM unit that should bolt right up to the Renegade remote water pump housing already in place in my car on the lower left hand side of the engine... that is assuming there is enough clearance between the water pump and the firewall. Would this work? I have heard stories going back and forth about mounting the pump by the radiator or by the engine. |
BRAVE_HELIOS |
May 29 2017, 02:28 PM
It was such a nice day; I decided to remove my bumper (as if I didn't have anything better to do!).
I have not taken it out for a drive yet to test cooling but I did want to show you all a a couple of things like the opening in the bulkhead and the rather large (for the Chalon bumper) ducting from the bumper to the bulkhead. Remember... I got that sucker so sealed that the fan will suck in a license plate to the grille! Do you think the bulkhead opening is large enough? I can probably remove those two rubber plugs to add a bit more to the air flow. What about the grille opening on the bumper... it is around 21 inch by 5 inch. Is it a sufficient size for the cooling? |
Lo-Fi Version | Time is now: 7th June 2024 - 09:21 AM |
