> anchoring 2 post lift, How did you do it?
Calwaterbear
post May 29 2017, 08:27 AM
Ok time to set-up my new/used 2 post lift. I poured a 14'X 25' pad, let it cure for 3 weeks.
So I will drill into the concrete and use 3/4 X 10'' wedge anchors. they will be 8" deep.
obviously the holes need to be drilled in exactly the right places, not only for each post, but also, the 2 posts have to be set at the exact width (dictated by the bar across the top, between the 2 posts).
so do i set up the posts, bolt on the top, then drill down through the feet?
Or use a template, put in the anchors, then drop the posts onto the anchors?
Bit of an issue is i am working alone, and even with a bobcat 763, i have not figured out a way to get the posts vertical yet, i plan on calling in my propane guy, who has a real live Ferrari crane on his service truck to lift em upright and position them.
Tech guys at Greg Smith say to drill the holes a couple of inched deeper than you will be anchoring at - so if you screw up, instead of having to cut off the anchor - you just drive it down in the slab. That seems like a good idea, but what if, while lowering the post, you miss and hit the top of the anchors, that would probably drive them down into the slab - No?
I'm probably overthinking this, but I'm hoping to draw from the experience of others who have gone before me on this venture!
forrestkhaag
post May 29 2017, 06:41 PM
Not to open a hornets nest here but what is the best two post lift? I am on two post Rotary's now and really appreciate the span between posts, speed of up and speed of down and range of vehicles the lift can lift.
Susan and I are going next week to Scottsdale to scoop acreage and builders / to build a 4 place minimum multi-lift garage with an upper deck mountain views studio over the top of it and I would like to start off on the right foot(ing).
This move is to get the hell out of California's regulations Whack-World (IMG:style_emoticons/default/hissyfit.gif) (IMG:style_emoticons/default/hissyfit.gif) (IMG:style_emoticons/default/sheeplove.gif) (IMG:style_emoticons/default/sheeplove.gif) (IMG:style_emoticons/default/sheeplove.gif) (IMG:style_emoticons/default/sheeplove.gif) - regulation of tool size, tool and useage noise ratios to protected rat bowl movement micro-decibel levels, number of tools allowed on one property in a commercial zone at one time (limited to two,.. to allow the folks with no tools or knowledge of the use of them an "opportunity" to learn) not to mention, the traffic that consumes 38% of productive wake time, (IMG:style_emoticons/default/hissyfit.gif) (IMG:style_emoticons/default/hissyfit.gif) (IMG:style_emoticons/default/hissyfit.gif)
Sidebar: We recently were cited by code enforcement for out house numerals being 1/4" too small - after twenty years of being OK / Now , in the new world, those brass numerals pose a hazard to our safety from police and fire intervention in case they need to find us.
They sure as (IMG:style_emoticons/default/barf.gif) could find us when we were in party mode....... (IMG:style_emoticons/default/WTF.gif) (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/beerchug.gif)
Calwaterbear   anchoring 2 post lift   May 29 2017, 08:27 AM
mepstein   Im not saying they are correct but there are a bun...   May 29 2017, 08:37 AM
Mark Henry   I put it in place and got it squared away, rented ...   May 29 2017, 09:06 AM
Calwaterbear   I put it in place and got it squared away, rented...   May 29 2017, 10:17 AM
DaveO90s4   drill the holes once it is all set up. That is the...   May 29 2017, 03:05 PM
URY914   Be sure to clean the holes out with a shop vac. Th...   May 29 2017, 04:00 PM
somd914   For me and a few helpers we stood the posts up by ...   May 29 2017, 05:30 PM
forrestkhaag   Not to open a hornets nest here but what is the be...   May 29 2017, 06:41 PM
Perry Kiehl   Not to open a hornets nest here but what is the b...   Jun 9 2017, 09:16 AM
Curbandgutter   I don't know if you did this but I would have ...   May 29 2017, 07:09 PM
Andyrew   Sounds like exactly what my dad did on his. He use...   May 29 2017, 08:03 PM
Mueller   Sounds like exactly what my dad did on his. He us...   Jun 1 2017, 10:59 AM
mepstein   Sounds like exactly what my dad did on his. He u...   Jun 1 2017, 01:02 PM
Calwaterbear   Sounds like exactly what my dad did on his. He u...   Jun 1 2017, 02:29 PM
914forme   They make epoxy set anchors for this job, don...   May 30 2017, 10:40 AM
Calwaterbear   They make epoxy set anchors for this job, don...   May 30 2017, 01:32 PM
PanelBilly   HF sells the drill and bits for concrete anchors. ...   May 30 2017, 01:27 PM
Cairo94507   Forestkhaagg - Yeah, I have to agree with the luna...   May 30 2017, 01:47 PM
mepstein   Forestkhaagg - Yeah, I have to agree with the lun...   Jun 1 2017, 11:57 AM
Calwaterbear   solved my standing up the posts dilemma. Had a BB...   Jun 1 2017, 09:45 AM
914_teener   solved my standing up the posts dilemma. Had a B...   Jun 1 2017, 10:48 AM
Phoenix-MN   when I cut the floor for a thicker pads I used a c...   Jun 1 2017, 02:45 PM
Vacca Rabite   when I cut the floor for a thicker pads I used a ...   Jun 1 2017, 08:04 PM
Phoenix-MN   my floor was also only about 4", IFIR they re...   Jun 2 2017, 08:33 PM
Calwaterbear   Ok guys, got it done, thanks for all the advise,...   Jun 8 2017, 09:44 AM
Mark Henry   Ok guys, got it done, thanks for all the advise...   Jun 8 2017, 04:46 PM
914_teener   So .....just curious. What was your engineeer conc...   Jun 8 2017, 03:51 PM
Mark Henry   Funny I had absolutely no problem installing my re...   Jun 8 2017, 05:00 PM
914_teener   Potential issues: 1. Wrong size bit. 2. Rebar 3...   Jun 8 2017, 05:08 PM
Calwaterbear   Potential issues: 3. High strength or large agg...   Jun 8 2017, 05:44 PM
Mark Henry   Your.re just good Mark. Nope, being good had ...   Jun 9 2017, 07:13 AM
914_teener   Your.re just good Mark. Nope, being good had...   Jun 9 2017, 09:04 AM
- Lo-Fi Version Time is now: 15th July 2025 - 10:55 AM
