mepstein |
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,319 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region ![]() ![]() |
Is there any reason I shouldn't consider working up a cable shifter instead of the traditional 916 shift linkage. The current 916 kit is $3-3250. Add in labor for machining and assembly and you're at $5k just to make the trans shift correctly. The suby guys are doing the shifting with $300 worth of cables and hardware. Am I missing something here?
rgalla9146 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,569 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None ![]() ![]() |
Is there any reason I shouldn't consider working up a cable shifter instead of the traditional 916 shift linkage. The current 916 kit is $3-3250. Add in labor for machining and assembly and you're at $5k just to make the trans shift correctly. The suby guys are doing the shifting with $300 worth of cables and hardware. Am I missing something here? I wonder if Martin Bott would sell his side shift parts separate from his complete 916 conversion kit ? The trans can be supported with a fabricated rear mount (which someone already makes)and the 915 rear cover and selector shaft can be trimmed to clear the muffler.(or not ?) If so, the only fabrication is the shift rod which is pretty straight forward and getting it to coordinate with a 915 shifter. Oh yeah, clutch cable too. PS I have the whole setup from Mr. Bott and already did the trans conversion but haven't gotten far enough with the car to actually drive it. There are certainly other ways to skin a cat. How about a Boxster trans ? |
larryM |
emoze ![]() ![]() ![]() Group: Members Posts: 891 Joined: 1-January 03 From: mid- California Member No.: 65 Region Association: Northern California ![]() ![]() |
check this - apparently Martin's parts ???
https://sfbay.craigslist.org/pen/pts/6146003135.html Porsche 915 to 916 Side Shifter Conversion Tooling and Parts. Description: 1 Set Detail Machining Drawings 1 Set San Casting Patterns 2 914-6 Firewall Engine Mount 3 Rear Castings 1 Machined Rear Casting. 3 Machined Side Shift Housing (One Is Assembled) 3 Internal Shift Arms ( 2 with Shafts) Total Price $5,500.00. who among us is the seller? p,s, - i have the complete Bott kit & a rebuilt 915 on the shelf - but have never had the compulsion to do the conversion since i have 3 good 901's & they'll handle 250hp which is all my 3.2 makes I wonder if Martin Bott would sell his side shift parts separate from his complete 916 conversion kit ? The trans can be supported with a fabricated rear mount (which someone already makes)and the 915 rear cover and selector shaft can be trimmed to clear the muffler.(or not ?) If so, the only fabrication is the shift rod which is pretty straight forward and getting it to coordinate with a 915 shifter. Oh yeah, clutch cable too. PS I have the whole setup from Mr. Bott and already did the trans conversion |
Lo-Fi Version | Time is now: 13th June 2024 - 02:01 AM |
