Removing tie rod, Tie rod attachment |
kaiserms |
Jun 6 2017, 06:59 PM
MSKaiser Group: Members Posts: 26 Joined: 8-September 16 From: waterford, michigan Member No.: 20,378 Region Association: Upper MidWest |
I am looking for some suggestions to remove the tie rod end from the steering connection, the part is attached to a smaller ball joint.
I must also note that the tie rods were changed to Turbo tie rods which shouldn't really make any difference. I have used PBBlaster, turned the castle nut over and tried to tap the splined end out with a hammer, (not a good idea since that ruins the splines). I have placed a pry bar across the tie rod and hammered on the tie rod. Does anyone have any suggestions to get the tie rod end to break free? Help appreciated. |
mgp4591 |
Jun 6 2017, 09:30 PM
914 Guru Group: Members Posts: 5,383 Joined: 1-August 12 From: Salt Lake City Ut Member No.: 14,748 Region Association: Intermountain Region |
You usually smack the end of the steering arm with a hammer sharply. That doesn't deform the arm if done correctly and the tie rod end should pop out - you really don't want to hit the threaded part. You can also borrow a tie rod end remover compression tool from Auto Zone - I hear it's free according to their commercials.
Lo-Fi Version | Time is now: 8th June 2024 - 06:29 AM |
