Removing tie rod, Tie rod attachment |
kaiserms |
Jun 6 2017, 06:59 PM
MSKaiser Group: Members Posts: 26 Joined: 8-September 16 From: waterford, michigan Member No.: 20,378 Region Association: Upper MidWest |
I am looking for some suggestions to remove the tie rod end from the steering connection, the part is attached to a smaller ball joint.
I must also note that the tie rods were changed to Turbo tie rods which shouldn't really make any difference. I have used PBBlaster, turned the castle nut over and tried to tap the splined end out with a hammer, (not a good idea since that ruins the splines). I have placed a pry bar across the tie rod and hammered on the tie rod. Does anyone have any suggestions to get the tie rod end to break free? Help appreciated. |
rhodyguy |
Jun 7 2017, 05:17 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,090 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Penetrant, repeatedly, be patient. Pointed bit in an air chisel. Tip in top of threaded end and have at it. You might have to repeat a few times but it should separate preserving the threads. Also helps if you solidly dunnage up the control arm.
Lo-Fi Version | Time is now: 8th June 2024 - 09:07 AM |
