> anchoring 2 post lift, How did you do it?
Calwaterbear
post May 29 2017, 08:27 AM
Ok time to set-up my new/used 2 post lift. I poured a 14'X 25' pad, let it cure for 3 weeks.
So I will drill into the concrete and use 3/4 X 10'' wedge anchors. they will be 8" deep.
obviously the holes need to be drilled in exactly the right places, not only for each post, but also, the 2 posts have to be set at the exact width (dictated by the bar across the top, between the 2 posts).
so do i set up the posts, bolt on the top, then drill down through the feet?
Or use a template, put in the anchors, then drop the posts onto the anchors?
Bit of an issue is i am working alone, and even with a bobcat 763, i have not figured out a way to get the posts vertical yet, i plan on calling in my propane guy, who has a real live Ferrari crane on his service truck to lift em upright and position them.
Tech guys at Greg Smith say to drill the holes a couple of inched deeper than you will be anchoring at - so if you screw up, instead of having to cut off the anchor - you just drive it down in the slab. That seems like a good idea, but what if, while lowering the post, you miss and hit the top of the anchors, that would probably drive them down into the slab - No?
I'm probably overthinking this, but I'm hoping to draw from the experience of others who have gone before me on this venture!
Calwaterbear
post Jun 8 2017, 09:44 AM
Ok guys, got it done, thanks for all the advise, experience and inputs!
I went with 11" long wedge anchor bolts, following engineer and manufacturer recommendations. I have used epoxied in anchors in the past - but the engineer insisted the drive in wedge anchors are stronger. That makes sense, as the bolt is tightened - the "collar" expands - so it is putting pressure on all sides of the concrete, as opposed to counting on the glue to bond with the concrete. I'm sure either way is fine.
But 2 unexpected issues showed up
1. once the drill hole got deeper than 4 or 5 inches, the shop vac would not pull out the dust. I'm using a 14 gallon 6 hp shop vac. -
to clean out the holes to the complete 9", required I used compressed air with a long nozzle, down the hole, with the shop vac sucking up the stuff as the air got it moving. That worked really well.
2. instructions and advise reminded me to thread the nut on the top of the anchor, to use that as the surface the hammer would hit , to preserve the threads. That turned into a fairly significant issue, as the driving of the anchor lead to the nut essentially deforming the threads of the anchor (redheads - 3/4") once that happened, you could not back off the nut, nor drive it on any further. trying to do so resulted in the anchor spinning in the hole - because the nut wasnt putting and upward pull to set the anchor. My solution was to set up a simple fulcrum (2X4 on its edge) with a 16" long wrench as the lever. I essentially stood on the end - that levered up , providing upward pull, that started the anchor holding in the concrete. Then I was able to pull off the nut, chase the treads with a die, clean out the threads of the nut with a tap.
I tried using 2 nuts back to back, and aftermarket nuts to take the pounding - and that allowed for driving the anchor, and could be removed without levering, but it still deformed the threads enough that I chased all of the anchors, before putting on the nuts, and torqueing it down.
so I'm not saying I did it all correctly, I did the best I could - but I am confident that the lift is anchored securely, and will not cause any issues moving forward!
Mark Henry
post Jun 8 2017, 04:46 PM
that's what I do!
QUOTE(Calwaterbear @ Jun 8 2017, 11:44 AM) *
Calwaterbear   anchoring 2 post lift   May 29 2017, 08:27 AM
mepstein   Im not saying they are correct but there are a bun...   May 29 2017, 08:37 AM
Mark Henry   I put it in place and got it squared away, rented ...   May 29 2017, 09:06 AM
Calwaterbear   I put it in place and got it squared away, rented...   May 29 2017, 10:17 AM
DaveO90s4   drill the holes once it is all set up. That is the...   May 29 2017, 03:05 PM
URY914   Be sure to clean the holes out with a shop vac. Th...   May 29 2017, 04:00 PM
somd914   For me and a few helpers we stood the posts up by ...   May 29 2017, 05:30 PM
forrestkhaag   Not to open a hornets nest here but what is the be...   May 29 2017, 06:41 PM
Perry Kiehl   Not to open a hornets nest here but what is the b...   Jun 9 2017, 09:16 AM
Curbandgutter   I don't know if you did this but I would have ...   May 29 2017, 07:09 PM
Andyrew   Sounds like exactly what my dad did on his. He use...   May 29 2017, 08:03 PM
Mueller   Sounds like exactly what my dad did on his. He us...   Jun 1 2017, 10:59 AM
mepstein   Sounds like exactly what my dad did on his. He u...   Jun 1 2017, 01:02 PM
Calwaterbear   Sounds like exactly what my dad did on his. He u...   Jun 1 2017, 02:29 PM
914forme   They make epoxy set anchors for this job, don...   May 30 2017, 10:40 AM
Calwaterbear   They make epoxy set anchors for this job, don...   May 30 2017, 01:32 PM
PanelBilly   HF sells the drill and bits for concrete anchors. ...   May 30 2017, 01:27 PM
Cairo94507   Forestkhaagg - Yeah, I have to agree with the luna...   May 30 2017, 01:47 PM
mepstein   Forestkhaagg - Yeah, I have to agree with the lun...   Jun 1 2017, 11:57 AM
Calwaterbear   solved my standing up the posts dilemma. Had a BB...   Jun 1 2017, 09:45 AM
914_teener   solved my standing up the posts dilemma. Had a B...   Jun 1 2017, 10:48 AM
Phoenix-MN   when I cut the floor for a thicker pads I used a c...   Jun 1 2017, 02:45 PM
Vacca Rabite   when I cut the floor for a thicker pads I used a ...   Jun 1 2017, 08:04 PM
Phoenix-MN   my floor was also only about 4", IFIR they re...   Jun 2 2017, 08:33 PM
Calwaterbear   Ok guys, got it done, thanks for all the advise,...   Jun 8 2017, 09:44 AM
Mark Henry   Ok guys, got it done, thanks for all the advise...   Jun 8 2017, 04:46 PM
914_teener   So .....just curious. What was your engineeer conc...   Jun 8 2017, 03:51 PM
Mark Henry   Funny I had absolutely no problem installing my re...   Jun 8 2017, 05:00 PM
914_teener   Potential issues: 1. Wrong size bit. 2. Rebar 3...   Jun 8 2017, 05:08 PM
Calwaterbear   Potential issues: 3. High strength or large agg...   Jun 8 2017, 05:44 PM
Mark Henry   Your.re just good Mark. Nope, being good had ...   Jun 9 2017, 07:13 AM
914_teener   Your.re just good Mark. Nope, being good had...   Jun 9 2017, 09:04 AM
- Lo-Fi Version Time is now: 15th July 2025 - 11:19 AM
