> anchoring 2 post lift, How did you do it?
Calwaterbear
post May 29 2017, 08:27 AM
Ok time to set-up my new/used 2 post lift. I poured a 14'X 25' pad, let it cure for 3 weeks.
So I will drill into the concrete and use 3/4 X 10'' wedge anchors. they will be 8" deep.
obviously the holes need to be drilled in exactly the right places, not only for each post, but also, the 2 posts have to be set at the exact width (dictated by the bar across the top, between the 2 posts).
so do i set up the posts, bolt on the top, then drill down through the feet?
Or use a template, put in the anchors, then drop the posts onto the anchors?
Bit of an issue is i am working alone, and even with a bobcat 763, i have not figured out a way to get the posts vertical yet, i plan on calling in my propane guy, who has a real live Ferrari crane on his service truck to lift em upright and position them.
Tech guys at Greg Smith say to drill the holes a couple of inched deeper than you will be anchoring at - so if you screw up, instead of having to cut off the anchor - you just drive it down in the slab. That seems like a good idea, but what if, while lowering the post, you miss and hit the top of the anchors, that would probably drive them down into the slab - No?
I'm probably overthinking this, but I'm hoping to draw from the experience of others who have gone before me on this venture!
Mark Henry
post Jun 8 2017, 05:00 PM
that's what I do!
Funny I had absolutely no problem installing my redheads , in fact I remember clearly I rented a hilti from home debit, drilled, drove them in and tightened them down and had the hilti back before the 4 hour minimum with time to spare.
It's a one hour round trip to home debit, so I must have done the deed in just over 2 hours.
Never had an issue hammering in the redheads. (IMG:style_emoticons/default/confused24.gif)
Calwaterbear   anchoring 2 post lift   May 29 2017, 08:27 AM
mepstein   Im not saying they are correct but there are a bun...   May 29 2017, 08:37 AM
Mark Henry   I put it in place and got it squared away, rented ...   May 29 2017, 09:06 AM
Calwaterbear   I put it in place and got it squared away, rented...   May 29 2017, 10:17 AM
DaveO90s4   drill the holes once it is all set up. That is the...   May 29 2017, 03:05 PM
URY914   Be sure to clean the holes out with a shop vac. Th...   May 29 2017, 04:00 PM
somd914   For me and a few helpers we stood the posts up by ...   May 29 2017, 05:30 PM
forrestkhaag   Not to open a hornets nest here but what is the be...   May 29 2017, 06:41 PM
Perry Kiehl   Not to open a hornets nest here but what is the b...   Jun 9 2017, 09:16 AM
Curbandgutter   I don't know if you did this but I would have ...   May 29 2017, 07:09 PM
Andyrew   Sounds like exactly what my dad did on his. He use...   May 29 2017, 08:03 PM
Mueller   Sounds like exactly what my dad did on his. He us...   Jun 1 2017, 10:59 AM
mepstein   Sounds like exactly what my dad did on his. He u...   Jun 1 2017, 01:02 PM
Calwaterbear   Sounds like exactly what my dad did on his. He u...   Jun 1 2017, 02:29 PM
914forme   They make epoxy set anchors for this job, don...   May 30 2017, 10:40 AM
Calwaterbear   They make epoxy set anchors for this job, don...   May 30 2017, 01:32 PM
PanelBilly   HF sells the drill and bits for concrete anchors. ...   May 30 2017, 01:27 PM
Cairo94507   Forestkhaagg - Yeah, I have to agree with the luna...   May 30 2017, 01:47 PM
mepstein   Forestkhaagg - Yeah, I have to agree with the lun...   Jun 1 2017, 11:57 AM
Calwaterbear   solved my standing up the posts dilemma. Had a BB...   Jun 1 2017, 09:45 AM
914_teener   solved my standing up the posts dilemma. Had a B...   Jun 1 2017, 10:48 AM
Phoenix-MN   when I cut the floor for a thicker pads I used a c...   Jun 1 2017, 02:45 PM
Vacca Rabite   when I cut the floor for a thicker pads I used a ...   Jun 1 2017, 08:04 PM
Phoenix-MN   my floor was also only about 4", IFIR they re...   Jun 2 2017, 08:33 PM
Calwaterbear   Ok guys, got it done, thanks for all the advise,...   Jun 8 2017, 09:44 AM
Mark Henry   Ok guys, got it done, thanks for all the advise...   Jun 8 2017, 04:46 PM
914_teener   So .....just curious. What was your engineeer conc...   Jun 8 2017, 03:51 PM
Mark Henry   Funny I had absolutely no problem installing my re...   Jun 8 2017, 05:00 PM
914_teener   Potential issues: 1. Wrong size bit. 2. Rebar 3...   Jun 8 2017, 05:08 PM
Calwaterbear   Potential issues: 3. High strength or large agg...   Jun 8 2017, 05:44 PM
Mark Henry   Your.re just good Mark. Nope, being good had ...   Jun 9 2017, 07:13 AM
914_teener   Your.re just good Mark. Nope, being good had...   Jun 9 2017, 09:04 AM
- Lo-Fi Version Time is now: 15th July 2025 - 11:09 AM
