TM_Corey |
Member ![]() ![]() Group: Members Posts: 231 Joined: 28-March 16 From: Indianapolis Member No.: 19,809 Region Association: Upper MidWest ![]() |
My horn seems possessed! Today on my way to cars and coffee it started beeping incontrollably on sharp right hand turns or over bumps. I have no reference to "norm" but it seems that the horn mechanism isn't attached super tightly to the steering wheel? Should it be fairly loose to wiggle, or is there a way I need to tighten it? It's the original set up in a 1974 2.0.
Also, check out these pics of my 914 and my 911S next to Graham Rahal's 918. That 918 was super sexy. First green one I have seen. Attached thumbnail(s) ![]() ![]() ![]() |
Dave_Darling |
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,196 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
There's a wire coming up through the center of the steering column. It has probably gotten unplugged from the ring on the back of the horn pad, or the tab on the pad has broken off.
You can cut a piece of metal into a new tab and braze or solder it onto the old ring, if the tab has broken off. --DD |
Lo-Fi Version | Time is now: 9th July 2025 - 12:19 PM |
