mb911 |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,593 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest ![]() ![]() |
Guys,
I have heard many cut the rear firewall in half prior to installing for ease. Anyone have a picture of where they cut it ? I am trying to get this info to Chris so he can send it with my floor pan |
Luke M |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,416 Joined: 8-February 05 From: WNY Member No.: 3,574 Region Association: North East States ![]() ![]() |
Hi Ben,
Are you replacing the full lower firewall with one of the RD parts? When my brother did his it wasn't too bad to do. It was kinda of a pain to do the heater tubes which we deleted anyways. Other then that there was no need to cut the firewall to install it. If you have the longs open on one side you could remove one of the tubes which will help the install. |
mb911 |
Hi Ben, Are you replacing the full lower firewall with one of the RD parts? When my brother did his it wasn't too bad to do. It was kinda of a pain to do the heater tubes which we deleted anyways. Other then that there was no need to cut the firewall to install it. If you have the longs open on one side you could remove one of the tubes which will help the install. Yes I am.. I was thinking it would just be easier around all the heater control tubes? |
Luke M |
Hi Ben, Are you replacing the full lower firewall with one of the RD parts? When my brother did his it wasn't too bad to do. It was kinda of a pain to do the heater tubes which we deleted anyways. Other then that there was no need to cut the firewall to install it. If you have the longs open on one side you could remove one of the tubes which will help the install. Yes I am.. I was thinking it would just be easier around all the heater control tubes? I believe you have the rear pan half off already. If you cut around the tubes then once the old firewall is off grind down the left over metal on each tube. We ended up replacing the inner half section as well so that helped out too. The e-brake cable and heater tubes would need to be removed/re install as the have the curve to them. I do not recall any other issue with the other tubes. Some pics of install here : http://www.914world.com/bbs2/index.php?sho...12849&st=20 |
mb911 |
Hi Ben, Are you replacing the full lower firewall with one of the RD parts? When my brother did his it wasn't too bad to do. It was kinda of a pain to do the heater tubes which we deleted anyways. Other then that there was no need to cut the firewall to install it. If you have the longs open on one side you could remove one of the tubes which will help the install. Yes I am.. I was thinking it would just be easier around all the heater control tubes? I believe you have the rear pan half off already. If you cut around the tubes then once the old firewall is off grind down the left over metal on each tube. We ended up replacing the inner half section as well so that helped out too. The e-brake cable and heater tubes would need to be removed/re install as the have the curve to them. I do not recall any other issue with the other tubes. Some pics of install here : http://www.914world.com/bbs2/index.php?sho...12849&st=20 That helps as well |
Lo-Fi Version | Time is now: 1st July 2025 - 10:46 PM |
