Welcome to the slippery slope..., Porsche 6-cylinder conversion |
Optimusglen |
Jun 15 2017, 09:21 AM
Senior Member Group: Members Posts: 911 Joined: 26-February 16 From: Minneapolis Member No.: 19,709 Region Association: Upper MidWest |
15 months ago I bought a crusty old 1971 914-4 that had been sitting in a garage for 20 years getting peed and chewed on by all sorts of creatures.
(IMG:http://www.914world.com/bbs2/uploads_offsite/c2.staticflickr.com-19709-1497540074.1.jpg) I started the project with a plan of it being driveable at the 1 year mark. Since then I've done an engine build, carb rebuild, brake rebuild with 5-lug swap, fuel system rebuild, interior rebuild, suspension rebuild, and some general freshening up. Oh, I forgot to mention that my wife and I had a baby too, safe to say it's been a pretty busy 15 months. Here's the build thread if anyone's interested. http://www.914world.com/bbs2/index.php?sho...=277349&hl= Anyway, the result is good. It's running and driving, the 1911 is strong and runs well. Handles great considering there are no sway bars. Tail shifter is as vague as you imagine though, and the engine is still sub 100hp so it's not incredibly fast. (IMG:http://www.914world.com/bbs2/uploads_offsite/c1.staticflickr.com-19709-1496565572.1.jpg) It's first real public appearance was at the June C&C that I attended with a good friend in his 911. (IMG:http://www.914world.com/bbs2/uploads_offsite/c1.staticflickr.com-19709-1497540075.2.jpg) Exiting a cloverleaf he pulled away like I was standing still. To add insult to injury a minivan pulled away too. This lit a little spark, I wanted more power. I started crunching numbers for building the type 4, goal is around 150hp. Can you get 150hp in a type 4 that's home built? Sure, lots of people have done it. But there's an even better, more expensive and headache inducing option... A friend of mine owns Flat Six in Minneapolis, MN. About 40 minutes from me. Sent him a message inquiring about core 6 cylinders and ended up coming home with this. (IMG:http://www.914world.com/bbs2/uploads_offsite/c1.staticflickr.com-19709-1497540075.3.jpg) It's a 2.2 from a 911T, the 125hp version. On top are a pair of Zenith carbs that will work fine for my purposes after a complete rebuild. It turns over smoothly and you can feel when it comes up on compression. Good signs for an otherwise unknown engine. If you had followed along in my build thread you'll know that I got some amazing deals, both for parts and for the car itself. The 6 does not disappoint in that regard, but I wont be sharing the details here. Perhaps the best part of the deal is that he said if I get into it and find that anything is FUBAR, I can get a no-charge replacement from him since he has Parted several 2.2's. Again, this is a friend, I don't expect him to do this for anyone. With his help we laid out a build plan. Going to get the T cams reground to the E profiles paired with higher compression pistons. Cylinders are iron so I can bore those. Goal is around 150ish hp. It'll be a "budget" build in the sense that I'm not going for huge power and will be doing the assembly/cleaning myself. I won't be cutting corners with machine work and inspection though. I will be mating it with a side-shift trans using the early 911 flywheel. flywheel and bulkhead weld-in mount already on order. It's not likely that I'll be doing a conventional 914-6 oil tank, it just seems like so much money for what you get. We will see though, as time progresses I may change my mind. This will be a driver, not trying to make it a show queen or original to a real 914-6. I want to keep the utility of both trunks but I want the mechanicals to be functionally excellent. Time frame is significantly longer than the original build. Planning at least a year or two considering the work and money involved. I'll update this thread moving forward and not my original build thread, kind of a new chapter if you will. Fortunately the 914 is perfectly driveable while I collect and rebuild. (IMG:style_emoticons/default/smile.gif) So here's to the next chapeter, however expensive and time consuming it may be. (IMG:http://www.914world.com/bbs2/uploads_offsite/media.giphy.com-19709-1497540075.4.gif) |
Krieger |
Jun 15 2017, 09:25 PM
Advanced Member Group: Members Posts: 4,723 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
Your sick, very sick! Good luck with the build!
Lo-Fi Version | Time is now: 2nd June 2024 - 05:18 PM |
