> 914 has spark n fuel wont start
peteyd
post Jun 16 2017, 06:23 AM
Hey was wondering if anybody could help me out ? I had a running car which started fine, we ran out of gas now it won't start. I checked the plugs, all kinds of fire, when I the pulled plugs out they were wet .then checked coil in distributor it reads 12.6 volt.. so took all plugs out checked compression cylinder 1 100psi cylinder 2 90 psi cylinder 3 90psi cylinder 4 70psi..is this to low or fine ?checked fuses they all look good. just got car on road and she dies
thanks in advance hoping it don't need rebuild ..
Pete
Spoke
post Jun 16 2017, 06:29 AM
Jerry
Compression looks good. Wet plugs are never a good sign. What type of induction? FI or carbs?
Squirting some starting fluid into the intake can indicate if the electrics and timing is ok.
Points or electronic ignition?
peteyd
post Jun 16 2017, 07:45 AM
QUOTE(Spoke @ Jun 16 2017, 04:29 AM) *
its fuel injected
peteyd
post Jun 16 2017, 07:46 AM
QUOTE(peteyd @ Jun 16 2017, 05:45 AM) *
its fuel injected
it has points
- Lo-Fi Version Time is now: 16th July 2025 - 12:21 PM
