Muffler Options for T4 Header, Updated to SpinTech Muffler |
7TPorsh |
Jul 28 2015, 04:49 PM
7T Porsh Group: Members Posts: 2,691 Joined: 27-March 06 From: Glendale Ca Member No.: 5,782 Region Association: Southern California |
Working out installing a msds T4 header and am considering muffler options. My first choice was to attach a flowmaster to the end of the collector and add a tail pipe....header exits on the driver's side.
It is turning out there may not be enough room since the header collector and reducer put the flange out near the end of the trans. I can route the pipe and muffler across the back and exit the passenger's side but then I need to change my valance. I think curving the pipe back to the driver's side will be tight; and hard to find a shop to spend the time. I remember seeing some kind of 911 muffler, banana type, that had the inlet and exit on the same side. Was that a custom job? Are they effective? Has anyone done this setup? How do you mount the muffler? |
7TPorsh |
Aug 7 2015, 11:28 AM
WHat do you guys do with the clutch and speedo cable? Mine is routed on top of the engine bar but it's rubbing the header now..Also I'm cooking the left side e-brake cable.
Do I need to re-do the clutch pulley somehow? |
Mark Henry |
Jun 16 2017, 10:06 AM
WHat do you guys do with the clutch and speedo cable? Mine is routed on top of the engine bar but it's rubbing the header now..Also I'm cooking the left side e-brake cable. Do I need to re-do the clutch pulley somehow? Fire sleeve and hose hangers. Tangerine had a pulley bracket that flips the bracket on it's side. (IMG:http://www.914world.com/bbs2/uploads_offsite/aircraftspruce.eu-26-1497629331.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/ae01.alicdn.com-26-1497629332.2.jpg) |
Lo-Fi Version | Time is now: 7th June 2024 - 11:22 PM |
