peteyd |
Senior Member ![]() ![]() ![]() Group: Members Posts: 737 Joined: 27-March 08 From: Elora, Ontario, Canada Member No.: 8,858 Region Association: Canada ![]() |
Hey was wondering if anybody could help me out ? I had a running car which started fine, we ran out of gas now it won't start. I checked the plugs, all kinds of fire, when I the pulled plugs out they were wet .then checked coil in distributor it reads 12.6 volt.. so took all plugs out checked compression cylinder 1 100psi cylinder 2 90 psi cylinder 3 90psi cylinder 4 70psi..is this to low or fine ?checked fuses they all look good. just got car on road and she dies
thanks in advance hoping it don't need rebuild .. Pete |
KeithVonLaws |
Member ![]() ![]() Group: Members Posts: 57 Joined: 19-July 16 From: Napoleon , Ohio 43545 Member No.: 20,205 Region Association: North East States ![]() |
Sounds like a CHT Issue to me... I have had the same problem in the past myself.
If you hook your Ohm meter to it you should have about 2500 Ohms at 68 degrees F. If you get a reading significantly higher than 2500 Ohms like I did the computer will command more fuel. If it is unplugged it will think it is -40 degrees F . And dump as much fuel as it can. You will likely need to change your oil too.... Good Luck |
Lo-Fi Version | Time is now: 16th July 2025 - 11:45 AM |
