> Mystery holes in passenger floor
doug_b_928
post Jun 18 2017, 07:17 AM
I have a couple of mystery holes in the passenger floor shown below. I'm sure they're for something, but I don't recall removing anything that attached there. What are they for?
doug_b_928
post Jun 18 2017, 12:36 PM
Hmmmmm.....Also makes me wonder why they didn't have drain holes on the driver's side (at least I don't recall seeing any). Maybe they figured water would run down the pedal cluster bolts (and sit in the pedal support bracket and rust it away).
doug_b_928   Mystery holes in passenger floor   Jun 18 2017, 07:17 AM
Garland   Cant recall the reason there, there. But two rubbe...   Jun 18 2017, 07:25 AM
doug_b_928   Interesting, thanks. I wonder if Mark has them......   Jun 18 2017, 07:29 AM
Krieger   You could use a little seam sealer.   Jun 18 2017, 08:05 AM
doug_b_928   True.   Jun 18 2017, 08:14 AM
gms   I would weld them up they are not needed   Jun 18 2017, 08:18 AM
doug_b_928   Yeah, I wondered about that too. I'm a bit of...   Jun 18 2017, 08:20 AM
rgalla9146   They let the water out.   Jun 18 2017, 09:53 AM
rgalla9146   They let the water out. Hold on a second. I...   Jun 18 2017, 05:37 PM
doug_b_928   Hold on a second. I don't mean to say the...   Jun 18 2017, 06:30 PM
doug_b_928   Interesting. I think they were covered in tar. I...   Jun 18 2017, 12:18 PM
euro911   I wonder if the same type of rubber drain nipples ...   Jun 18 2017, 12:32 PM
doug_b_928   Hmmmmm.....Also makes me wonder why they didn...   Jun 18 2017, 12:36 PM
Mikey914   Put a set of front trunk drain tubes in there. The...   Jun 18 2017, 06:18 PM
euro911   Put a set of front trunk drain tubes in there. The...   Jun 18 2017, 08:02 PM
Garland   The holes are original, and use the flat rubber pl...   Jun 18 2017, 10:16 PM
doug_b_928   Great, thanks very much for providing the photo of...   Jun 19 2017, 07:19 AM
mepstein   I'm pretty sure the red circled hole is for dr...   Jun 19 2017, 07:24 AM
doug_b_928   Makes sense. Looks to have been a bit of an after...   Jun 19 2017, 07:27 AM
rgalla9146   What year is the car ? If they are original I...   Jun 21 2017, 03:18 PM
doug_b_928   73   Jun 21 2017, 03:49 PM
doug_b_928   I actually just discovered that there are 4 plugs ...   Jun 21 2017, 04:39 PM
euro911   I actually just discovered that there are 4 plugs ...   Jun 21 2017, 05:08 PM
Rand   Does anyone really think about water drain? Like w...   Jun 21 2017, 04:50 PM
doug_b_928   Point well taken, but his car won't see drinks...   Jun 21 2017, 04:57 PM
doug_b_928   Excellent, thanks.   Jun 21 2017, 05:12 PM
rgalla9146   Uncle   Jun 21 2017, 06:29 PM
Matty900   You could use stoppers or drain tubes.   Jun 21 2017, 09:24 PM
Matty900   The previous owner of my car drilled 2 holes behin...   Jun 21 2017, 09:38 PM
doug_b_928   Great pics! I'm missing one of the stoppe...   Jun 21 2017, 10:02 PM
Matty900   Great pics! I'm missing one of the stopp...   Jun 21 2017, 10:41 PM
doug_b_928   Yep, those are the ones I was referring to and the...   Jun 22 2017, 08:26 AM
gms   My friend had his unrestored 1973 with only 20 som...   Jun 25 2017, 11:47 AM
- Lo-Fi Version Time is now: 15th April 2026 - 09:21 AM
