> Mystery holes in passenger floor
doug_b_928
post Jun 18 2017, 07:17 AM
I have a couple of mystery holes in the passenger floor shown below. I'm sure they're for something, but I don't recall removing anything that attached there. What are they for?
doug_b_928
post Jun 21 2017, 04:39 PM
I actually just discovered that there are 4 plugs that look the same as those pictured above in the bottom of the Frunk (I couldn't see them from above because they had been painted over). There were two empty holes in the middle of the frunk floor. Is that where the two drain tubes that Mark makes go?
doug_b_928   Mystery holes in passenger floor   Jun 18 2017, 07:17 AM
Garland   Cant recall the reason there, there. But two rubbe...   Jun 18 2017, 07:25 AM
doug_b_928   Interesting, thanks. I wonder if Mark has them......   Jun 18 2017, 07:29 AM
Krieger   You could use a little seam sealer.   Jun 18 2017, 08:05 AM
doug_b_928   True.   Jun 18 2017, 08:14 AM
gms   I would weld them up they are not needed   Jun 18 2017, 08:18 AM
doug_b_928   Yeah, I wondered about that too. I'm a bit of...   Jun 18 2017, 08:20 AM
rgalla9146   They let the water out.   Jun 18 2017, 09:53 AM
rgalla9146   They let the water out. Hold on a second. I...   Jun 18 2017, 05:37 PM
doug_b_928   Hold on a second. I don't mean to say the...   Jun 18 2017, 06:30 PM
doug_b_928   Interesting. I think they were covered in tar. I...   Jun 18 2017, 12:18 PM
euro911   I wonder if the same type of rubber drain nipples ...   Jun 18 2017, 12:32 PM
doug_b_928   Hmmmmm.....Also makes me wonder why they didn...   Jun 18 2017, 12:36 PM
Mikey914   Put a set of front trunk drain tubes in there. The...   Jun 18 2017, 06:18 PM
euro911   Put a set of front trunk drain tubes in there. The...   Jun 18 2017, 08:02 PM
Garland   The holes are original, and use the flat rubber pl...   Jun 18 2017, 10:16 PM
doug_b_928   Great, thanks very much for providing the photo of...   Jun 19 2017, 07:19 AM
mepstein   I'm pretty sure the red circled hole is for dr...   Jun 19 2017, 07:24 AM
doug_b_928   Makes sense. Looks to have been a bit of an after...   Jun 19 2017, 07:27 AM
rgalla9146   What year is the car ? If they are original I...   Jun 21 2017, 03:18 PM
doug_b_928   73   Jun 21 2017, 03:49 PM
doug_b_928   I actually just discovered that there are 4 plugs ...   Jun 21 2017, 04:39 PM
euro911   I actually just discovered that there are 4 plugs ...   Jun 21 2017, 05:08 PM
Rand   Does anyone really think about water drain? Like w...   Jun 21 2017, 04:50 PM
doug_b_928   Point well taken, but his car won't see drinks...   Jun 21 2017, 04:57 PM
doug_b_928   Excellent, thanks.   Jun 21 2017, 05:12 PM
rgalla9146   Uncle   Jun 21 2017, 06:29 PM
Matty900   You could use stoppers or drain tubes.   Jun 21 2017, 09:24 PM
Matty900   The previous owner of my car drilled 2 holes behin...   Jun 21 2017, 09:38 PM
doug_b_928   Great pics! I'm missing one of the stoppe...   Jun 21 2017, 10:02 PM
Matty900   Great pics! I'm missing one of the stopp...   Jun 21 2017, 10:41 PM
doug_b_928   Yep, those are the ones I was referring to and the...   Jun 22 2017, 08:26 AM
gms   My friend had his unrestored 1973 with only 20 som...   Jun 25 2017, 11:47 AM
- Lo-Fi Version Time is now: 15th April 2026 - 09:23 AM
