| kbsmith1973 |
Jun 23 2017, 07:50 AM
Newbie ![]() Group: Members Posts: 4 Joined: 22-June 17 From: Arkansaw, WI Member No.: 21,206 Region Association: Upper MidWest |
I'm trying to replace the air filter element in my 1973 914 1.7L. Fram CA-383 was the prior replacement.
I got one from my local parts store, but it didn't fit properly. Subsequently I ordered one from one of the big Porsche outfits online. It was the same as the one from the local store! The 'recommended' replacement has a larger inside diameter, causing it to miss the sealing ring in the lower part of the housing. It will leak outside air directly into the engine. Internet search has not turned up anything on this issue. Any ideas? |
| stinkindiesel |
Jun 28 2017, 01:25 PM
Member ![]() ![]() Group: Members Posts: 184 Joined: 14-June 13 From: Georgetown, TX Member No.: 16,012 Region Association: Southwest Region |
I posted this a while back.
Dimensions: Mann C2180 (OEM, NLA) 124mm ID 207mm OD 82mm tall Here's what I'm running now. Wix 42110 125mm ID 163mm OD 76mm tall It's 6mm too short, so I cut a piece of cork gasket material the same size as the filter to fill the extra gap. I found 1/4" to be too much, so I think I've got a couple of pieces in there now that are just under 1/4" total. ![]() ![]() ![]() ![]() Gary |
kbsmith1973 1.7L Airfilter Replacement Jun 23 2017, 07:50 AM
BillC There are a number of threads on this. Turns out ... Jun 23 2017, 08:00 AM
kbsmith1973 Thanks. I'll try your idea.
Too bad I couldn... Jun 23 2017, 12:00 PM
914_teener There is a FLAPS replacement that is really close.... Jun 23 2017, 01:39 PM![]() ![]() |
Lo-Fi Version | Time is now: 16th May 2026 - 09:36 PM |
