kkid |
Member ![]() ![]() Group: Members Posts: 346 Joined: 18-December 07 From: Oakland, CA Member No.: 8,483 Region Association: Northern California ![]() |
Hey guys,
So my Creamsicle project is coming to the end. Got a new paint, good engine and tranny, and etc. The rear brake calipers are stuck so I switched those with other pair. Now it has fairly new PMB massaged calipers and was easy to adjust the clearance with no problems. But when I connected the e-brake cables to the calipers one cable is too short to attach to the arm so it tends to pull the arm with the e-brake handle in down position. I have already adjusted to max at the cable housing adjusting nuts at the firewall. Do I have a wrong cable or can I adjust the angle of the caliper arm??? OR I have screwed up something???? Other side is within the adjustable range to not pull at rest position. Has anybody else encountered this before? Thanks, kkid (IMG:style_emoticons/default/smile.gif) |
Lo-Fi Version | Time is now: 26th August 2025 - 09:37 PM |
