dudzy's914 |
The youngin' ![]() ![]() Group: Members Posts: 271 Joined: 21-December 13 From: Hatfield, MA Member No.: 16,784 Region Association: North East States ![]() |
My front trunk seal will just not stay in place. How does it stay in?
Thanks, Finn |
Lucky9146 |
Always Wanted A Bigger Go Cart ![]() ![]() ![]() Group: Members Posts: 1,677 Joined: 22-September 14 From: Poway California Member No.: 17,942 Region Association: Southern California ![]() ![]() |
Tom_T |
TMI.... ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,321 Joined: 19-March 09 From: Orange, CA Member No.: 10,181 Region Association: Southern California ![]() ![]() |
I used this. 3 M Super Weatherstrip and Gasket Adhesive. Yellow. Commonly referred to as "snake snot" worked perfect on mine Good luck ![]() I think that there are black gasket adhesives out there which will do as good of a job & not scream YELLOW around the edges of your gasket. Permatex makes a good one which we used on our 88 Westy's pop-top seal, which has a lot of pulling forces when lifting the top up. And what mark/Mikey914 said - whether his 914Rubber repros or factory seals - the bottom is usually flat(-ish), & IIRC the 914 Factory Repair Manual says to run a small bead in the tray on the body [not on the seal bottom]. If not adhered, then the seals tend to pull apart at the 8 corners - especially the front corners ones around the headlight buckets. If yours tear/separate, then you can use that same Permatex gasket/seal adhesive to repair them with a dab inside the joint at the corners, then adhere in place in the tray. Good Luck! (IMG:style_emoticons/default/beerchug.gif) Tom /////// |
Lo-Fi Version | Time is now: 16th July 2025 - 10:55 PM |
