| JFG |
Jun 29 2017, 01:48 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 686 Joined: 7-April 16 From: Wales Member No.: 19,869 Region Association: None |
The vw replacement alternator number is 021-903-023-A,
On the 914 parts catalog it is 022 903 023. Looking at images online i see the vw has some kind of suppressor on it (causing shorts until remedied) the one on my engine (likely a 411) does not have this. It also has no numbers on it. Does the 914 alternator have the suppressor? Can i fit the vw numbered alternator without issues? |
| Mikey914 |
Jul 7 2017, 11:43 AM
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,772 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None
We have made the replacement harness with the correct cap on it. Also working on the deflector, boot, and some other little goodies that fit in there. Unfortunately, they are several weeks out. But the harness is in stock if you need one. Do check to see if the 3 prong connector is brittle, and it the red wire has evidence of melting the protective covering.
http://shop.914rubber.com/Alternator-wirin...m?categoryId=-1 Here's a code for $15 off it you need one "ALT10" In fact one of those parts is also ready and on sale (I'll start a dedicated thread) Hope this helps Attached thumbnail(s) Attached image(s)
JFG alternator suitability Jun 29 2017, 01:48 PM
Mikey914 Good question :popcorn: Jun 29 2017, 11:53 PM
JFG For those as electronically challenged as myself I... Jul 6 2017, 11:20 AM
mgphoto Problems arise with the positive lug, our type iv ... Jul 6 2017, 02:27 PM
914Sixer Positive terminal (red wire) is supposed to have a... Jul 6 2017, 07:33 PM
JFG You're both correct in what you say. The posit... Jul 7 2017, 11:14 AM
jim_hoyland
We have made the replacement harness with the cor... Jul 7 2017, 04:02 PM![]() ![]() |
Lo-Fi Version | Time is now: 5th March 2026 - 08:48 AM |
