Biggles |
Member ![]() ![]() Group: Members Posts: 200 Joined: 5-September 13 From: UK Member No.: 16,353 Region Association: England ![]() |
Has anyone out there got ideas or carried out an alternative system to fix the front bonnet (hood) when it's a GRP panel (the one with the balsa wood inserts)?
My reasons for this are two fold: 1) the front latch on it's own is not enough and 2) my car is a road car and I just don't want to use unsightly pins. I had thought about using a solenoid mounted on the headlight triangular hinge plate that when the ignition is on, it throws out a bolt which engages a latch on the underside of the bonnet locking it in place until the ignition is turned off - only problem there I've discovered is getting a small enough solenoid which can be run continuously (generally they get hot which is a fire risk). A curved latch system like on a door might be an alternative but not sure how to disengage the latch once the bonnet is shut. I've run out of ideas, so any good thoughts welcomed. thanks |
ConeDodger |
Apex killer! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,150 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California ![]() ![]() |
Biggles,
Just how fast are you going? Before I put the hood pins on mine I just used the factory latch, which I still use in addition to the pins for security. While it was just the factory latch, I didn't have a problem. You pretty much cannot use the hood Springs or it bows the hood about midway on both sides. |
Biggles |
Biggles, Just how fast are you going? Before I put the hood pins on mine I just used the factory latch, which I still use in addition to the pins for security. While it was just the factory latch, I didn't have a problem. You pretty much cannot use the hood Springs or it bows the hood about midway on both sides. yes, but it's added security as you say, as there isn't much torsional rigidity in the panel really. I'm aware that the springs have to come off as it'll over power the panel. Chris. |
Lo-Fi Version | Time is now: 22nd August 2025 - 10:46 AM |
