Biggles |
Member ![]() ![]() Group: Members Posts: 200 Joined: 5-September 13 From: UK Member No.: 16,353 Region Association: England ![]() |
Has anyone out there got ideas or carried out an alternative system to fix the front bonnet (hood) when it's a GRP panel (the one with the balsa wood inserts)?
My reasons for this are two fold: 1) the front latch on it's own is not enough and 2) my car is a road car and I just don't want to use unsightly pins. I had thought about using a solenoid mounted on the headlight triangular hinge plate that when the ignition is on, it throws out a bolt which engages a latch on the underside of the bonnet locking it in place until the ignition is turned off - only problem there I've discovered is getting a small enough solenoid which can be run continuously (generally they get hot which is a fire risk). A curved latch system like on a door might be an alternative but not sure how to disengage the latch once the bonnet is shut. I've run out of ideas, so any good thoughts welcomed. thanks |
barefoot |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,424 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States ![]() ![]() |
Instead of solenoids, you could run cables to both sides & mounted next to the regular hood latch cable.
Lo-Fi Version | Time is now: 22nd August 2025 - 10:48 AM |
