> 911 oil filter "drama"
Keith914
post Jul 9 2017, 08:34 AM
I am at final stage of completing my 2.7 911 engine install project. All external oil lines are AN12 stainless steel braided hoses and fittings. I have the scavenger oil feeding directly into an oil filter which is mounted to a bracket with 1/2" fittings for the in and out and for the nipple that the filter screws onto. While starting the engine, as soon as rpm's exceed about 2000 the filter O ring pops out and oil leaks massively. Same result after several attempts. I have a K&N filter that has a large O ring that is not as secure in it's groove as say FRAM filters I am familiar with, and which worked well with this bracket fitting when I had my Type IV in the car. I will be installing a new bracket shortly that has 1/2" in and out hose fittings but a 3/4" nipple for a new typical 911 filter which has a matching 3/4" screw on female fitting. I decided not to install an oil thermostat as I live in a warm climate here in S Cal. Any advice will be welcome.
Mark Henry
post Jul 9 2017, 04:32 PM
that's what I do!
1/2" NPT is still a tad small IMO.
All the AN-12 stuff (which is correct size for a front cooler) is wasted, as you flow will be restricted to 1/2"
The filter adapter should be AN-10 or 5/8" sized, which is right about the stock tank/filter size.
porschetub
post Jul 10 2017, 09:26 PM
QUOTE(Mark Henry @ Jul 10 2017, 10:32 AM) *
Good call Mark the smallest pipe in the system is the return ,things must be matched up ,no wonder things are going to (IMG:style_emoticons/default/stromberg.gif) .
Good luck Keith,you will get there.
Keith914   911 oil filter "drama"   Jul 9 2017, 08:34 AM
mb911   I think 1/2" is to small as stock would be 5/...   Jul 9 2017, 08:42 AM
Mark Henry   I think 1/2" is to small as stock would be 5...   Jul 9 2017, 08:49 AM
wndsrfr   WIX 51515R.....made for high pressure that we get ...   Jul 11 2017, 10:58 AM
Mark Henry   Could you explain how you have the oil filter moun...   Jul 9 2017, 08:44 AM
Keith914   Could you explain how you have the oil filter mou...   Jul 9 2017, 09:31 AM
Steve   I know your trying to save money, but if you bough...   Jul 9 2017, 09:52 AM
Steve   duplicate post   Jul 9 2017, 09:53 AM
Mark Henry   :ttiwwp:   Jul 9 2017, 10:52 AM
Mark Henry   Not sure what you mean by oil filter bracket.... I...   Jul 9 2017, 10:54 AM
Keith914   Not sure what you mean by oil filter bracket.... ...   Jul 9 2017, 11:06 AM
rhodyguy   Should that remote require a Mann filter designed ...   Jul 9 2017, 11:16 AM
Mark Henry   Should that remote require a Mann filter designed...   Jul 9 2017, 11:21 AM
Keith914   Should that remote require a Mann filter designe...   Jul 9 2017, 11:52 AM
Steve   If your going to go that route, I would check out ...   Jul 9 2017, 11:20 AM
Mark Henry   Same thing you have but in 1" NPT, any hydrau...   Jul 9 2017, 11:59 AM
Keith914   Same thing you have but in 1" NPT, any hydra...   Jul 9 2017, 12:09 PM
thelogo   Your a brave man sir keith Putting all this s...   Jul 9 2017, 12:28 PM
Keith914   Your a brave man sir keith Putting all this ...   Jul 9 2017, 01:30 PM
Mark Henry   If it's a mahle I'd look elsewhere than th...   Jul 9 2017, 02:14 PM
Keith914   If it's a mahle I'd look elsewhere than t...   Jul 9 2017, 03:15 PM
Mark Henry   1/2" NPT is still a tad small IMO. All the A...   Jul 9 2017, 04:32 PM
mb911   1/2" NPT is still a tad small IMO. All the ...   Jul 10 2017, 02:19 PM
porschetub   1/2" NPT is still a tad small IMO. All the ...   Jul 10 2017, 09:26 PM
Larmo63   Keith came by to pick up the Patrick sourced Peter...   Jul 10 2017, 12:30 AM
Keith914   Installed the in-line filter that Larmo sold to me...   Jul 13 2017, 09:09 AM
- Lo-Fi Version Time is now: 8th December 2025 - 01:15 AM
