IronHillRestorations |
I. I. R. C. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,849 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None ![]() ![]() |
I'm making a harness that needs a power circuit switched via relay.
I've got generic Bosch style 5 pin relays, and I'm seeing a voltage drop on the power out side of the relay. It's rare that I make a harness that needs a relay, and in the few that I've done with a relay circuit, this has never been reported as a problem. I'm not an electrical engineer, but I always thought a relay was just an electro-mechanical switch and I should be getting the same voltage on the output. Just to be clear for those who do know more about this than me, none of the wires that I'm using to test this are more than 24" long and none are less than 14 gauge wire. The relay power is for a coil pack, so I'm sure that needs a good 12+ volts. |
jd74914 |
Its alive ![]() ![]() ![]() ![]() Group: Members Posts: 4,853 Joined: 16-February 04 From: CT Member No.: 1,659 Region Association: North East States ![]() |
Do you know the circuit load (current)? How are you testing the drop? As Mark said there shouldn't be much drop across a good mechanical relay since there is minimal contact resistance. Could you be pulling down the power supply voltage?
Lo-Fi Version | Time is now: 21st August 2025 - 04:54 AM |
