> Voltage drop on relay circuit?, 12v down to 10.5v
IronHillRestorations
post Jul 11 2017, 11:46 AM
I. I. R. C.
I'm making a harness that needs a power circuit switched via relay.
I've got generic Bosch style 5 pin relays, and I'm seeing a voltage drop on the power out side of the relay.
It's rare that I make a harness that needs a relay, and in the few that I've done with a relay circuit, this has never been reported as a problem.
I'm not an electrical engineer, but I always thought a relay was just an electro-mechanical switch and I should be getting the same voltage on the output.
Just to be clear for those who do know more about this than me, none of the wires that I'm using to test this are more than 24" long and none are less than 14 gauge wire.
The relay power is for a coil pack, so I'm sure that needs a good 12+ volts.
Spoke
post Jul 11 2017, 08:52 PM
Jerry
It's called "fog in the cockpit". Happens to everyone at one time or another.
Bottom line, does the relay work?
post Jul 12 2017, 08:31 AM
I. I. R. C.
QUOTE(Spoke @ Jul 11 2017, 06:52 PM) *
Yes
- Lo-Fi Version Time is now: 21st August 2025 - 04:55 AM
